StarTech.com USB-C to HDMI Adapter - 4K60Hz
Quicklinx: CHN2WS00 Mfr#: CDP2HD4K60W
22 In Stock
£16.32 ex VAT
£19.58 inc VAT
Connect your USB Type-C laptop to an Ultra HD 60Hz display or projector. This USB-C to HDMI adapter lets you output HDMI video and audio from a USB Type-C device, with support for Ultra HD 4K at 60Hz. The adapter works with USB-C devices that pass a DisplayPort video signal, and it's also compatible with Thunderbolt 3 ports. The USB-C video adapter features a sleek white design that looks great with your USB Type-C enabled MacBook or HP ENVY 13.
The adapter lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask, while working on the most resource-demanding applications imaginable. With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60Hz, which is perfect for performing high-resolution tasks such as viewing and editing 4K video.
The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
With its all-white design, this USB-C video adapter is the perfect accessory for your MacBook with USB-C. The adapter is compact and lightweight so it fits easily into your MacBook bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office. While the adapter looks great next your Mac and HP ENVY, it also works with any USB-C computer that supports DisplayPort ALT mode, such as your Windows laptop.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in. The reversible connector means you will always plug it in correctly on your first try. It saves you the hassle and distraction of repeatedly attempting to connect your laptop to a display or projector, while you're delivering a presentation or speaking to a group.
  • Astonishing picture quality
    The adapter lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask, while working on the most resource-demanding applications imaginable. With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60Hz, which is perfect for performing high-resolution tasks such as viewing and editing 4K video. The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
  • The perfect travel companion
    This USB-C video adapter is the perfect accessory for your MacBook with USB-C. The adapter is compact and lightweight so it fits easily into your MacBook bag or carrying case, which is great for BYOD applications at the office. While the adapter looks great next your Mac and HP ENVY, it also works with any USB-C computer that supports DisplayPort ALT mode, such as your Windows laptop.
  • Hassle-free connection with USB Type-C
StarTech.com USB-C to HDMI Adapter - White - 4K 60Hz - adapter - HDMI / USB - 15 cm
Cable
High Speed - adapter - HDMI / USB
Max Output Resolution
3840 x 2160 - 60 Hz
Length
15 cm
White
Connector
24 pin USB-C - male (input)
Connector (Second End)
HDMI - female (output)
4K support
3-year warranty
Cable Type
High Speed - adapter 4K support
Interface Supported
HDMI / USB
Jacket Material
Plastic
Length
15 cm
32 audio channels, DisplayPort Alternate Mode support
White
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connector
19 pin HDMI Type A - female (output)
FCC, RoHS, WEEE, REACH, RCM
2.5 cm
1.1 cm
21 g
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.2 cm
Shipping Weight
30 g
Limited warranty - 3 years
CHN2 StarTech.com USB-C to VGA Adapter In Stock £21.62
CHN2 StarTech.com USB-C to HDMI Adapter In Stock £16.61
CHN2 StarTech.com USB-C to HDMI Adapter In Stock £18.89
CHN2 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £7.79
CHN2 StarTech.com 2m USB-C to DVI Cable In Stock £22.21
CHN2 StarTech.com 2m USB-C to HDMI Cable In Stock £27.69
CHN2 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
CHN2 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.85
CHN2 StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £19.66
CHN2 StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £16.32
CHN2 StarTech.com USB-C to HDMI - Power Delivery In Stock £23.36
CHN2 StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £18.96
CHN2 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.05
CHN2 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £22.84
CHN2 StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £19.58
CHN2 StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.81
CHN2 StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £11.44
CHN2 StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.56
CHN2 StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.99
CHN2 StarTech.com 3ft (1m) USB C to HDMI Cable 4K 60Hz /HDR10 - USB-C to HDMI In Stock £17.16
CHN2 StarTech.com 6ft (2m) USB C to HDMI Cable 4K 60Hz / HDR10 - USB-C to HDMI In Stock £17.96
CHN2 StarTech.com 9.8ft (3m) USBC to HDMI Cable 4K USB-C HDMI Media Convertor In Stock £24.53
CHN2 StarTech.com 13ft (4m) USB C to HDMI Cable 4K HDMI USB-C to HDMI Monitor In Stock £11.01
CHN2 StarTech.com 16ft (5m) USB C to HDMI Cable 4K USB-C to HDMI Monitor Conve In Stock £26.26
CHN2 StarTech.com USB C to HDMI Adapter 4K 60Hz In Stock £12.26
CHN2 StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £22.60
