This USB-C to HDMI adapter lets you connect your USB Type-C laptop to an HDMI display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
With brighter colors and greater contrast, the adapter is ideal for: Creating eye-catching visuals for photography, videography, cinematography; Displaying crisp digital signage walls; Delivering enriched presentations.
The USB-C video adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 X 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI and DisplayPort at their supported maximum resolutions.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
This lightweight 4K adapter is highly portable, with a small-footprint design. It's the perfect accessory for your USB-C laptop or MacBook, fitting easily into your carrying case.
To ensure easy operation and installation, this unique USB-C to HDMI adapter includes a reversible USB-C connector so you will always plug it into your laptop correctly on the first try.
To achieve HDR, your USB-C port must support DisplayPort 1.4 and your display must support HDMI 2.0b. NVIDIA graphics adapters may not support 4:4:4 chroma subsampling and 5.1/7.1 audio output, when used with this adapter.
True 4K at 60Hz and HDR
The USB-C video adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 X 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI and DisplayPort at their supported maximum resolutions. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. -
Ideal for Travel
This lightweight 4K adapter is highly portable, with a small-footprint design. It's the perfect accessory for your USB-C laptop or MacBook, fitting easily into your carrying case. -
Hassle-Free Setup
To ensure easy operation and installation, this unique USB-C to HDMI adapter includes a reversible USB-C connector so you will always plug it into your laptop correctly on the first try. CDP2HD4K60H is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes:
- StarTech.com USB 3.1 Type C to HDMI Adapter with HDR - 4K 60Hz - TB3 Compatible - Windows & Mac Compatible Black USB C to HDMI Monitor Converter (CDP2HD4K60H) - external video adapter - MegaChips MCDP2900 - black
- External video adapter
- Bus Type
- USB-C
- Graphics Engine
- Max Resolution
- 4096 x 2160
- Interfaces Details
- HDMI (female connector)
- 2.86 cm 1.14 cm
- Length
- 5.6 cm
- Enclosure Colour
- Black
- 3-year warranty
- Designed For
- P/N: ST121HD20FXA, TB4CDOCK
- Bus Type
- USB-C
- Graphics Engine
- Max Resolution
- 4096 x 2160 at 60 Hz
- HDR Ready
- Cables Included
- USB-C cable - 10.41 cm
- FCC, RoHS, DisplayPort 1.4
- 2.86 cm
- 1.14 cm
- Length
- 5.6 cm
- 30 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 25 - 60%
- Designed For
StarTech.com USB-C to HDMI Adapter | In Stock | £17.39 |
StarTech.com USB-C to HDMI Adapter | In Stock | £19.04 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £12.23 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £17.28 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.15 |
StarTech.com USB-C to HDMI Adapter - 4K60Hz | In Stock | £17.36 |
StarTech.com USB-C to VGA, DVI or HDMI | In Stock | £38.72 |
StarTech.com 5m 15ft Premium 4K HDMI Cable | In Stock | £24.31 |
StarTech.com 7m 23ft Premium 4K HDMI Cable | In Stock | £35.86 |
StarTech.com 0.5m Premium 4K HDMI Cable | In Stock | £10.74 |
StarTech.com 3ft (1m) USB C to HDMI Cable 4K 60Hz /HDR10 - USB-C to HDMI | In Stock | £16.39 |
StarTech.com 6ft (2m) USB C to HDMI Cable 4K 60Hz / HDR10 - USB-C to HDMI | In Stock | £18.18 |
StarTech.com 9.8ft (3m) USBC to HDMI Cable 4K USB-C HDMI Media Convertor | In Stock | £19.75 |
StarTech.com 13ft (4m) USB C to HDMI Cable 4K HDMI USB-C to HDMI Monitor | In Stock | £11.01 |
StarTech.com 16ft (5m) USB C to HDMI Cable 4K USB-C to HDMI Monitor Conve | In Stock | £23.80 |
