This USB-C to DisplayPort adapter cable lets you connect your USB Type-C device to a DisplayPort monitor with just one cable, providing you with a convenient, clutter-free solution.
Supporting four times the resolution of 4K, this8K DP 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps.
With cutting-edge picture quality, this adapter is ideal for: Displaying crisp digital signage walls; Creating eye-catching visuals for photography and videography.
The DP adapter is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
At 5.9 ft. (1.8 m) in length, this adapter delivers a direct connection that eliminates excess cabling, ensuring a tidy installation. For installations requiring a shorter length, a 3.3 ft. (1 m) (CDP2DP141MB) DisplayPort cable enables you to customize your connection needs.
To ensure easy operation, this DP adapter supports plug-and-play installation, removing the need for additional software or drivers.
Note: Your USB-C device must support DP Alt Mode to work with this adapter.
High-resolution support
This cable accommodates video output up to 7680 x 4320, allowing for detail and clarity in visuals. -
Smooth video performance
With a V-Sync rate of 60 Hz at maximum resolution, this cable ensures playback for an enhanced viewing experience. -
Broad compatibility
Designed to support Thunderbolt 3, this cable offers flexibility for use with a variety of devices and configurations. -
Advanced features
It includes HBR3 support, ensuring the highest bandwidth and performance for demanding applications. -
Secure connection
The male DisplayPort connector provides a reliable and stable connection, minimizing the risk of signal loss.
- StarTech.com 6ft/1.8m USB C to DisplayPort 1.4 Cable, 4K/5K/8K USB Type-C to DP 1.4 Alt Mode Video Adapter Converter, HBR3/HDR/DSC, 8K 60Hz DP 1.4 Monitor Cable for USB-C and Thunderbolt 3 - 8K USB-C to DP Cable - external video adapter - black
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 7680 x 4320
- Interfaces Details
- DisplayPort (male connector)
- Length
- 1.8 m
- Enclosure Colour
- Black
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
- Bus Type
- USB-C
- Max Resolution
- 7680 x 4320 at 60 Hz
- 8K Display Support, Thunderbolt 3 compatible, DisplayPort Alternate Mode, HBR3 support
- DisplayPort 1.4
- Length
- 1.8 m
- Enclosure Colour
- Black
- Limited warranty - 3 years
- Designed For
- P/N: TB4CDOCK
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £10.00 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £8.35 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £6.73 |
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £17.93 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £22.59 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £20.19 |
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable | In Stock | £17.71 |
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K | In Stock | £23.05 |
StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter | In Stock | £12.38 |
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz | In Stock | £16.65 |
