StarTech.com USB-C to HDMI Adapter - 4K60Hz
Quicklinx: CHN2WS00 Mfr#: CDP2HD4K60W
More than 50 in stock
£20.73 ex VAT
£24.87 inc VAT
Connect your USB Type-C laptop to an Ultra HD 60Hz display or projector. This USB-C to HDMI adapter lets you output HDMI video and audio from a USB Type-C device, with support for Ultra HD 4K at 60Hz. The adapter works with USB-C devices that pass a DisplayPort video signal, and it's also compatible with Thunderbolt 3 ports. The USB-C video adapter features a sleek white design that looks great with your USB Type-C enabled MacBook or HP ENVY 13.
The adapter lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask, while working on the most resource-demanding applications imaginable. With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60Hz, which is perfect for performing high-resolution tasks such as viewing and editing 4K video.
The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
With its all-white design, this USB-C video adapter is the perfect accessory for your MacBook with USB-C. The adapter is compact and lightweight so it fits easily into your MacBook bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office. While the adapter looks great next your Mac and HP ENVY, it also works with any USB-C computer that supports DisplayPort ALT mode, such as your Windows laptop.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in. The reversible connector means you will always plug it in correctly on your first try. It saves you the hassle and distraction of repeatedly attempting to connect your laptop to a display or projector, while you're delivering a presentation or speaking to a group.
StarTech.com USB C to HDMI Adapter - White - 4K 60Hz - Thunderbolt 3 Compatible - USB Type C to HDMI Dongle Converter (CDP2HD4K60W) - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI
2.5 cm 1.1 cm
Length
15 cm
Enclosure Colour
White
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI
FCC, RoHS
2.5 cm
1.1 cm
Length
15 cm
23 g
Enclosure Colour
White
Limited warranty - 3 years
5 °C
35 °C
25 - 85% (non-condensing)
CHN2 StarTech.com USB-C to VGA Adapter In Stock £23.65
CHN2 StarTech.com USB-C to VGA Adapter - White In Stock £21.53
CHN2 StarTech.com USB-C to HDMI Adapter In Stock £17.77
CHN2 StarTech.com USB-C to DVI Adapter In Stock £20.24
CHN2 StarTech.com USB-C to DVI Adapter - White In Stock £20.24
CHN2 StarTech.com USB-C to HDMI Adapter - 4K 60Hz In Stock £20.79
CHN2 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £8.22
CHN2 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £11.32
CHN2 StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £10.72
CHN2 StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £20.73
Price Range Ex VAT: 0 - 50
