Connect your USB Type-C laptop to an Ultra HD 60Hz display or projector. This USB-C to HDMI adapter lets you output HDMI video and audio from a USB Type-C device, with support for Ultra HD 4K at 60Hz. The adapter works with USB-C devices that pass a DisplayPort video signal, and it's also compatible with Thunderbolt 3 ports. The USB-C video adapter features a sleek white design that looks great with your USB Type-C enabled MacBook or HP ENVY 13.
The adapter lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask, while working on the most resource-demanding applications imaginable. With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60Hz, which is perfect for performing high-resolution tasks such as viewing and editing 4K video.
The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
With its all-white design, this USB-C video adapter is the perfect accessory for your MacBook with USB-C. The adapter is compact and lightweight so it fits easily into your MacBook bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office. While the adapter looks great next your Mac and HP ENVY, it also works with any USB-C computer that supports DisplayPort ALT mode, such as your Windows laptop.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in. The reversible connector means you will always plug it in correctly on your first try. It saves you the hassle and distraction of repeatedly attempting to connect your laptop to a display or projector, while you're delivering a presentation or speaking to a group.
Astonishing picture quality
The adapter lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask, while working on the most resource-demanding applications imaginable. With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60Hz, which is perfect for performing high-resolution tasks such as viewing and editing 4K video. The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications. -
The perfect travel companion
This USB-C video adapter is the perfect accessory for your MacBook with USB-C. The adapter is compact and lightweight so it fits easily into your MacBook bag or carrying case, which is great for BYOD applications at the office. While the adapter looks great next your Mac and HP ENVY, it also works with any USB-C computer that supports DisplayPort ALT mode, such as your Windows laptop. -
Hassle-free connection with USB Type-C
- Startech USB-C to HDMI Adapter - White - 4K 60Hz - adapter - HDMI / USB - 15 cm
- Cable
- Adapter - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Cable Length
- 15 cm
- White
- Connector
- USB-C - male (input)
- Connector (Second End)
- HDMI - female (output)
- 4K support
- 3-year warranty
- Cable Type
- Adapter 4K support
- Interface Supported
- HDMI / USB
- Jacket Material
- Plastic
- Cable Length
- 15 cm
- 32 audio channels, DisplayPort Alternate Mode support
- White
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- Connector
- 24 pin USB-C - male (input)
- 19 pin HDMI Type A - female (output)
- FCC, RoHS, WEEE, REACH, RCM
- 2.5 cm
- 1.1 cm
- 21 g
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.2 cm
- Shipping Weight
- 30 g
- Limited warranty - 3 years
StarTech.com USB-C to VGA Adapter | In Stock | £22.16 |
StarTech.com USB-C to HDMI Adapter | In Stock | £15.93 |
StarTech.com USB-C to HDMI Adapter | In Stock | £15.52 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £7.64 |
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £18.05 |
StarTech.com 2m USB-C to DVI Cable | In Stock | £23.46 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £27.94 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £16.00 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.46 |
StarTech.com USB-C to HDMI Adapter - 4K60Hz | In Stock | £16.30 |
StarTech.com USB-C to HDMI - Power Delivery | In Stock | £23.58 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.36 |
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable | In Stock | £18.04 |
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K | In Stock | £23.05 |
StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter | In Stock | £12.45 |
StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? | In Stock | £20.49 |
StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable | In Stock | £11.44 |
StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.89 |
StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.97 |
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz | In Stock | £16.65 |
StarTech.com 3ft (1m) USB C to HDMI Cable 4K 60Hz /HDR10 - USB-C to HDMI | In Stock | £16.60 |
StarTech.com 6ft (2m) USB C to HDMI Cable 4K 60Hz / HDR10 - USB-C to HDMI | In Stock | £17.41 |
StarTech.com 9.8ft (3m) USBC to HDMI Cable 4K USB-C HDMI Media Convertor | In Stock | £20.01 |
StarTech.com 13ft (4m) USB C to HDMI Cable 4K HDMI USB-C to HDMI Monitor | In Stock | £21.82 |
StarTech.com 16ft (5m) USB C to HDMI Cable 4K USB-C to HDMI Monitor Conve | In Stock | £24.18 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £12.49 |
StarTech.com 6.6ft USB C to DP 1.2 Cable | In Stock | £31.29 |
