StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz
Quicklinx: C4Y0WS00 Mfr#: CDP2DPMM1MB
Length: 1m
Select:
Hurry, only 1 left in stock!
£13.11 ex VAT
£15.73 inc VAT
This USB-C to DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DisplayPort monitor or projector, at up to 1 m (3 ft.) away.
The adapter works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, this adapter cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For longer installations, StarTech.com also offers an 1.8 m (6 ft.) USB-C to DP cable (CDP2DPMM6B), enabling you to choose the right cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect, saving you the frustration of trying to insert it correctly when you're trying to dock your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
  • High-resolution support
    This cable allows for a maximum output resolution of 3840 x 2160, providing clear images and vivid color reproduction, perfect for demanding applications like gaming and video editing.
  • Fast data transfer
    With a data rate of 21.6 Gbps, this cable ensures smooth and quick data transmission, making it ideal for high-performance tasks such as streaming and gaming.
  • Audio channel support
    The cable supports 5.1 audio channel, delivering an audio experience that enhances entertainment and multimedia experiences.
  • Compatibility
    Designed with DisplayPort Alternate Mode and HBR2 support, this cable ensures compatibility with a range of devices and delivers optimal performance.
  • Solid build quality
    The cable is constructed to comply with FCC, RoHS, HDCP 2.2, and HDCP 1.4 standards, ensuring reliability and durability for long-term use.
StarTech.com 3ft/1m USB C to DisplayPort 1.2 Cable 4K 60Hz, USB-C to DisplayPort Adapter Cable HBR2, USB Type-C DP Alt Mode to DP Monitor Video Cable, Compatible with Thunderbolt 3, Black - USB-C Male to DP Male (CDP2DPMM1MB) - DisplayPort cable - 24 pin USB-C to DisplayPort - 1 m
DisplayPort cable
4K60Hz (3840 x 2160) support, HBR2 support, DisplayPort Alternate Mode support, 21.6 Gbps data rate, 5.1 audio channel support
Length
1 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
20 pin DisplayPort - male (output)
Displayport 1.2/Thunderbolt 3
3-year warranty
P/N: TB33A1C, TB3DK2DPM2, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB3DOCK2DPPD, TB3DOCK2DPPU
DisplayPort cable
Length
1 m
34 g
Connector
Displayport 1.2/Thunderbolt 3, FCC, RoHS, HDCP 2.2, HDCP 1.4
Shipping Width
13.4 cm
Shipping Depth
15.1 cm
Shipping Height
1.2 cm
Shipping Weight
42 g
3-year warranty
C4Y0 StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £13.69
C4Y0 StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.52
C4Y0 StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £8.54
C4Y0 StarTech.com USB-C to VGA Adapter - White In Stock £23.49
C4Y0 StarTech.com USB-C to HDMI Adapter In Stock £18.89
C4Y0 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £13.11
C4Y0 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £13.19
C4Y0 StarTech.com USB-C to DisplayPort MST Hub - 2-Port In Stock £38.47
C4Y0 StarTech.com 2m USB-C to DVI Cable In Stock £22.21
C4Y0 StarTech.com 2m USB-C to HDMI Cable In Stock £27.69
C4Y0 StarTech.com 1m USB-C to DVI Cable In Stock £20.32
C4Y0 StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £16.33
C4Y0 StarTech.com 1m USB-C to HDMI Cable In Stock £25.04
C4Y0 StarTech.com 1m USB-C to VGA Cable In Stock £19.38
C4Y0 StarTech.com 2m USB-C to VGA Cable In Stock £20.80
C4Y0 StarTech.com USB-C to HDMI - Power Delivery In Stock £23.36
C4Y0 StarTech.com USB-C to DisplayPort Adapter In Stock £21.40
C4Y0 StarTech.com USB-C to DisplayPort Adapter In Stock £19.75
C4Y0 StarTech.com 2m USB C to HDMI Cable - Black In Stock £26.55
C4Y0 StarTech.com 1m USB C to HDMI Cable - Black In Stock £27.08
C4Y0 StarTech.com 3m USB C to HDMI Cable - Black In Stock £26.60
C4Y0 StarTech.com 1m USB C to HDMI Cable - White In Stock £22.47
C4Y0 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.05
C4Y0 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £22.84
C4Y0 StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £19.58
C4Y0 StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.81
C4Y0 StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £21.95
C4Y0 StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.56
C4Y0 StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.99
C4Y0 StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £28.36
C4Y0 StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £22.60
Length: 1m
