StarTech.com 2m USB-C to HDMI Cable
Quicklinx: CFQMWS00 Mfr#: CDP2HDMM2MB
More than 50 In Stock
£27.94 ex VAT
£33.52 inc VAT
Eliminate clutter by connecting your USB Type-C computer directly to an HDMI display without additional adapters. This USB-C to HDMI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your HDMI monitor, television or projector. The adapter supports a connection distance of up to 2 m (6 ft.) and works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 2 m (6 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, a 1 m (3 ft.) USB-C to HDMI cable enabl you to choose the right cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display.
The adapter is backward compatible with 1080p displays, ensuring the adapter will also work for HD applications at your home or office.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
  • Clutter-free installation
    At 2 m (6 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, we also offer a 1 m (3 ft.) USB-C to HDMI cable, enabling you to choose the right cable length for your custom installation needs.
  • Hassle-free connection with USB Type-C
  • Astonishing picture quality
    At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display. The adapter is backward compatible with 1080p displays, ensuring the adapter will also work for HD applications at your home or office. The CDP2HDMM2MB is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note: Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
StarTech USB C to HDMI Adapter Cable - USB Type-C HDMI - 2m 6 ft. - 4K - external video adapter
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
Interfaces Details
HDMI (male connector)
Cable Length
2 m
3-year warranty
P/N: TB33A1C
Bus Type
USB-C
Max Resolution
3840 x 2160
Interfaces Details
FCC, RoHS, WEEE
Cable Length
2 m
Limited warranty - 3 years
45 °C
5 - 95% (non-condensing)
P/N: TB33A1C
CFQM StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M In Stock £9.20
CFQM StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £10.40
CFQM StarTech.com HDMI Coupler / Gender Changer - F/F In Stock £8.59
CFQM StarTech.com USB-C to HDMI Adapter In Stock £15.93
CFQM StarTech.com USB-C to HDMI Adapter In Stock £15.52
CFQM StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £7.64
CFQM StarTech.com 6ft USB-C to DisplayPort Cable In Stock £18.72
CFQM StarTech.com 2m USB-C to DVI Cable In Stock £23.46
CFQM StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
CFQM StarTech.com 1m USB-C to DVI Cable In Stock £11.22
CFQM StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £16.30
CFQM StarTech.com 1m USB-C to HDMI Cable In Stock £25.27
CFQM StarTech.com 1m USB-C to VGA Cable In Stock £19.38
CFQM StarTech.com 2m USB-C to VGA Cable In Stock £21.96
CFQM StarTech.com USB-C to HDMI - Power Delivery In Stock £23.58
CFQM StarTech.com USB-C to HDMI Presentation In Stock £14.13
CFQM StarTech.com 6 ft USB C to DP Cable - White In Stock £9.11
CFQM StarTech.com 2m USB C to HDMI Cable - Black In Stock £28.04
CFQM StarTech.com 1m USB C to HDMI Cable - Black In Stock £28.42
CFQM StarTech.com 3m USB C to DisplayPort Cable - White In Stock £20.18
CFQM StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £26.32
CFQM StarTech.com 3m USB C to HDMI Cable - Black In Stock £28.08
CFQM StarTech.com 1m USB C to HDMI Cable - White In Stock £22.55
CFQM StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £9.71
CFQM StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £20.26
CFQM StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.04
CFQM StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £23.05
CFQM StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.80
CFQM StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £11.44
CFQM StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.89
CFQM StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.97
CFQM StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £16.65
CFQM StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £31.29
