StarTech.com USB-C to HDMI Presentation
Quicklinx: CQSNWS00 Mfr#: CDP2HD4K60SA
Select:
  • HDMI
28 In Stock
£13.38 ex VAT
£16.05 inc VAT
Connect your USB-C computer to an HDMI display, and prevent your laptop display from going to sleep during a presentation or meeting. This is no ordinary video adapter. Yes, it enables you to connect the USB-C port on your computer to an HDMI display or projector, but it also features a unique Presentation Mode switch. When you turn on this switch, the adapter prevents your computer from launching its screen saver, going to sleep or entering power save mode. The adapter ensures that your screen will always stay on, making it the perfect USB-C video adapter for any presentation or meeting.
When you deliver a presentation, your goal is to engage with your audience, not your computer. But, if you don't move your mouse soon enough, or change your power settings, your screen goes black due to inactivity while you're addressing the audience. This can be a major distraction when you're trying to focus on the message you're communicating.
This adapter prevents screen disruptions with Presentation Mode, a unique feature that automatically initiates occasional cursor movement to prevent your computer's power settings from interrupting your presentation. It's perfect for sharing websites, drawings, spreadsheets, PDFs or slide shows during your meeting.
You can turn Presentation Mode on or off depending on your application. Turn it on when you're in the boardroom and want your screen to stay on, and turn it off when you're using the adapter at your workspace or office hot desk, to enable your computer's original power settings to take effect. Using the toggle switch is easy, and saves you the hassle of constantly making adjustments in your operating system settings.
To ensure easy operation and installation, this unique adapter is natively supported on Windows and Mac computers. It's easy to connect the adapter using the versatile USB Type-C port on your computer. The reversible USB-C connector means you will always plug it in correctly on your first try, which saves you the hassle and distraction of repeatedly attempting to connect your laptop to a display or projector.
This adapter lets you harness the video capabilities that are built into your computer's USB Type-C connection, to deliver astonishing UHD 4K 60Hz resolution to your HDMI 2.0 display. This makes it easier for you to multitask while you work on the most resource-demanding applications imaginable.
With this adapter, you can achieve an output resolution of up to 3840 x 2160p at 60Hz, which is perfect for performing high-resolution tasks such as viewing 4K video. Plus, the adapter is backward compatible with 1080p displays, which makes it a great travel accessory ensuring you can connect to any boardroom display or projector.
StarTech.com USB C to 4K HDMI Adapter - 4K 60Hz - Thunderbolt 3 Compatible - USB Type C to HDMI Video Display Adapter (CDP2HD4K60SA) - adapter - HDMI / USB - TAA Compliant - 19 cm
Cable
Adapter - HDMI / USB
TAA Compliant
Max Output Resolution
3840 x 2160 - 60 Hz
Length
19 cm
Connector
24 pin USB-C - male (input)
Connector (Second End)
HDMI - female (output)
Thunderbolt 3
4K60Hz (3840 x 2160) support
3-year warranty
P/N: TB4CDOCK
Cable Type
Adapter 4K60Hz (3840 x 2160) support
Interface Supported
HDMI / USB
Thunderbolt 3
Length
19 cm
7.1 channel Surround Sound, Presentation Mode
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connector
19 pin HDMI Type A - female (output)
FCC, RoHS
TAA Compliant
4.3 cm
1.6 cm
Shipping Width
8.2 cm
Shipping Depth
23.5 cm
Shipping Height
2.2 cm
Shipping Weight
67 g
Limited warranty - 3 years
P/N: TB4CDOCK
CQSN StarTech.com USB-C to VGA Adapter In Stock £22.31
CQSN StarTech.com USB-C to HDMI Adapter In Stock £17.04
CQSN StarTech.com USB-C to HDMI Adapter In Stock £18.65
CQSN StarTech.com 2m USB-C to DVI Cable In Stock £22.91
CQSN StarTech.com 2m USB-C to HDMI Cable In Stock £27.26
CQSN StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £12.23
CQSN StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.37
CQSN StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £19.66
CQSN StarTech.com USB-C to HDMI - Power Delivery In Stock £23.00
CQSN StarTech.com USB-C to HDMI Presentation In Stock £13.38
CQSN StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £18.71
CQSN StarTech.com USB C to mDP Adapter 12" Cable In Stock £14.49
