This USB-C to HDMI adapter lets you connect your USB Type-C laptop to an HDMI display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video. With brighter colors and greater contrast, the adapter is ideal for: • Creating eye-catching visuals for photography, videography, cinematography • Displaying crisp digital signage walls • Delivering enriched presentations.
True 4K at 60Hz and HDR
The USB-C video adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 X 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI at their supported maximum resolutions. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. -
Ideal for Travel
This lightweight 4K adapter is highly portable, with a small-footprint design. It's the perfect accessory for your USB-C laptop or MacBook, fitting easily into your carrying case. -
Hassle-Free Setup
To ensure easy operation and installation, this unique USB-C to HDMI adapter includes a reversible USB-C connector so you will always plug it into your laptop correctly on the first try. USBC-HDMI-CDP2HD4K60 is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes:
- Startech USB C to HDMI Adapter, 4K 60Hz UHD Video, HDR10, USB-C to HDMI 2.0b Adapter Dongle, USB Type-C DP Alt Mode to HDMI Monitor/Display/Projector, USB C to HDMI Converter, M/F - Thunderbolt 3 Compatible - adapter - HDMI / USB - 13 cm
- Cable
- Adapter - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Cable Length
- 13 cm
- Space grey
- Connector
- USB-C - male (input)
- Connector (Second End)
- HDMI - female (output)
- Thunderbolt 3
- Active adapter, 4K60Hz (3840 x 2160) support
- 3-year warranty
- Cable Type
- Adapter active, 4K60Hz (3840 x 2160) support
- Interface Supported
- HDMI / USB
- Jacket Material
- Plastic
- Thunderbolt 3
- Cable Length
- 13 cm
- HDR 10 support, DisplayPort Alternate Mode support, 7.1 PCM audio channel support, ANX7517 chipset
- Space grey
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- Connector
- 24 pin USB-C - male (input)
- 19 pin HDMI Type A - female (output)
- FCC, RoHS, WEEE, REACH, RCM
- 2.2 cm
- 1.05 cm
- 16 g
- Shipping Width
- 12.5 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 22 g
- Limited warranty - 3 years
