The GCMDP2DPMF Mini DisplayPort to DisplayPort adapter/converter allows you to add a standard DisplayPort connection port to your existing laptop or Mac Mini. Easy to use and install, this cost-effective solution makes it easy for you to go from Mini DP to DP, in order to get the most from your Mini DisplayPort device.
- StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - Mini DP (m) to DP (f) Converter Adapter (GCMDP2DPMF) - DisplayPort adapter
- Connector
- DisplayPort - female
- Connector (Second End)
- Mini DisplayPort - male
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2DP141MB, CDP2DP146B, CDP2DPMM1MB, CDP2DPMM6B, DISPLPORT10L, DISPLPORT15L, DISPLPORT3L, DISPLPORT6L, DP2DVIADAP, DP2HDS
- Plated Connector
- Nickel
- Black
- Connector
- 20 pin DisplayPort - female
- RoHS
- Designed For
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £12.15 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £22.37 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £22.82 |
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.27 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.32 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £15.22 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.05 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £11.66 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £14.83 |
StarTech.com 1m Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £13.74 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.32 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £12.11 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.12 |
