StarTech.com USB-C to 4K HDMI Adapter with Power Delivery
Quicklinx: CFR5WS00 Mfr#: CDP2HDUACP
£45.81 ex VAT
£54.97 inc VAT
Connect your USB Type-C laptop to an HDMI display and a USB Type-A peripheral device, plus power and charge your laptop. This universal multifunction adapter lets you expand the connectivity of your laptop or MacBook through USB-C . You can connect your laptop to a 4K HDMI display, while also connecting a traditional USB 3.0 device. And, when coupled with your laptop's power adapter, the multiport adapter delivers power to help charge and maintain your laptop's battery.
This compact USB-C adapter is a vital accessory for your MacBook, Chromebook, or any USB-C equipped laptop. It's extremely portable, with a lightweight, small-footprint design that tucks neatly into your laptop bag or carrying case.
The rugged multifunction adapter meets the tough demands of travelers. Now you can rest assured knowing your adapter is ready when you are.
If you have a 4K HDMI display, you can connect it to this combo adapter to create a dual-monitor workstation (laptop display + external display). With an additional display, you can get more work done at once by multitasking more efficiently. Plus, 4K resolution lets you enjoy astonishing picture quality, with rich and vivid realism.
Whether you're delivering a presentation in a boardroom or looking to add a display to your existing laptop workstation, this adapter is a must-have accessory.
Because this versatile adapter supports USB Power Delivery, you can power and charge your laptop through its USB Type-C port. Simply connect the adapter to your laptop's USB-C port, and then connect your laptop's power adapter to the multifunction adapter.
By using a single power adapter to power your laptop and the adapter, instead of using multiple adapters, you can travel lighter and more conveniently. Plus, you can reduce cable clutter in your work area.
Unlike some proprietary laptop adapters designed only to work with specific laptop models, this universal adapter works with multiple brands. All you need is a laptop's USB-C port that supports DP alt mode and USB Power Delivery, and you can be up and running quickly. With universal support, you can use this adapter with different laptops now, or in the future. Plus, it's compatible with Thunderbolt 3 ports.
This USB-C multifunction adapter features a USB 3.0 port that's backward compatible with older USB devices. It's perfect for data transfers, syncing, or charging your mobile device.
StarTech.com USB-C to HDMI Adapter - 4K 30Hz - Thunderbolt 3 Compatible - with Power Delivery (USB PD) - USB C Adapter Converter (CDP2HDUACP) - docking station - USB-C / Thunderbolt 3 - HDMI
Docking station
Docking Interface
Video Interfaces
HDMI
5 cm x 6 cm x 1.1 cm
35 g
3-year warranty
Docking station
5 cm
6 cm
1.1 cm
35 g
Enclosure Colour
Video
Max Resolution Details
4096 x 2160 - 24 Hz , 3840 x 2160 - 30 Hz
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1
1 x USB-C 3.1 Gen 1 with Power Delivery (60W) - 24 pin USB-C (power only) , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
1 x USB-C cable - integrated - 10.1 cm
USB powered, 60W power delivery
FCC, RoHS, USB Power Delivery 2.0, UASP (USB Attached SCSI Protocol)
Limited warranty - 3 years
Shipping Width
14.6 cm
Shipping Depth
17.5 cm
Shipping Height
3.2 cm
Shipping Weight
118 g
CFR5 StarTech.com 2m Thunderbolt 3 20Gbps Cable In Stock £40.57
CFR5 StarTech.com 1m Thunderbolt 3 20Gbps Cable In Stock £33.89
CFR5 StarTech.com 0.5m Thunderbolt 3 Cable In Stock £29.76
CFR5 StarTech.com USB-C Multifunction Adapter In Stock £47.42
CFR5 StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £45.81
CFR5 StarTech.com USB-C to VGA Adapter with PD In Stock £12.06
CFR5 StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.98
CFR5 StarTech.com USB-C Adapter - PD - Silver In Stock £47.42
CFR5 StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £26.04
CFR5 StarTech.com USB-C Multiport Adapter - DVI In Stock £22.67
CFR5 StarTech.com 0.5m Thunderbolt 3 Cable White In Stock £10.76
CFR5 StarTech.com 1m Thunderbolt 3 Cable White In Stock £33.00
CFR5 StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £70.33
CFR5 StarTech.com 2m Thunderbolt 3 Cable White In Stock £39.59
CFR5 StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 In Stock £60.64
CFR5 StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB In Stock £37.45
CFR5 StarTech.com USB-C Adapter with HDMI & VGA In Stock £29.93
CFR5 StarTech.com USB-C Multiport Adapter, 4K HDMI or VGA, Type-C Mini Dock In Stock £60.11
CFR5 StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock In Stock £23.20
CFR5 StarTech.com USB C Multiport Adapter 4K In Stock £32.06
CFR5 StarTech.com USBC Multiport Adapter 4K HDMI In Stock £23.99
CFR5 StarTech.com USB C Multiport Adapter PD, 4K In Stock £20.67
CFR5 StarTech.com USB-C Multiport Adapter HDMI In Stock £53.20
CFR5 StarTech.com USB C Multiport Adapter In Stock £15.24
CFR5 StarTech.com Multiport Adapter HDMI/VGA In Stock £20.09
CFR5 StarTech.com USB C Multiport Adapter, 4K In Stock £26.96
CFR5 StarTech.com USB C Multiport Adapter 4K In Stock £26.62
CFR5 StarTech.com USB C Mini Dock 4K HDMI In Stock £42.54
CFR5 StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £33.64
CFR5 StarTech.com USB C Multiport Adapter 2 HDMI In Stock £65.89
CFR5 StarTech.com USB C Dock DP 4K30Hz or VGA In Stock £82.39
CFR5 StarTech.com USB-C Multiport Adapter In Stock £22.01
CFR5 StarTech.com USB C Multiport Adapter In Stock £82.76
CFR5 StarTech.com USB-C Multiport Adapter, HDMI In Stock £28.21
CFR5 StarTech.com USB-C Multiport Adapter, HDMI In Stock £25.65
CFR5 StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £43.75
CFR5 StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £27.87
CFR5 StarTech.com USB-C Speakerphone Dock In Stock £79.25
CFR5 StarTech.com USB-C Triple-Monitor Adapter In Stock £76.93
CFR5 StarTech.com USB-C/USB-A Multiport Adapter In Stock £46.41
CFR5 StarTech.com USB-C Triple-Monitor Adapter In Stock £80.56
