Deliver professional presentations in any meeting or conference room. You can create a permanent or temporary workstation virtually anywhere you go and deliver professional presentations in any meeting or conference room.
This versatile USB-C multiport adapter for laptops makes it easy to create a mobile workstation when you need it most. It features HDMI and VGA ports, so you can easily connect a 4K HDMI or a standard-definition VGA monitor.
Installation is fast and easy, with native support in most operating systems. Plus, the adapter integrates a Gigabit Ethernet port and an additional USB 3.0 port, so you can access a wired network, or connect an additional USB peripheral to your laptop.
The host laptop USB-C port must support DP Alt Mode.
The presentation remote features a sleek, ergonomic design with a wireless range of 90 feet (27 m) and includes the required batteries and a carrying case. The USB receiver is supported by generic HID drivers, ensuring it will work with virtually any Mac or Windows computer.
With a built-in laser pointer, the presentation remote lets you guide your audience's attention to critical information in your on-screen content. It's perfect for PowerPoint presentations, websites or any other visuals you want to share with an audience.
Create a Mobile Workstation
This versatile USB-C multiport adapter for laptops makes it easy to create a mobile workstation when you need it most. It features HDMI and VGA ports, so you can easily connect a 4K HDMI or a standard-definition VGA monitor. Installation is fast and easy, with native support in most operating systems. Plus, the adapter integrates a Gigabit Ethernet port and an additional USB 3.0 port, so you can access a wired network, or connect an additional USB peripheral to your laptop. The host laptop USB-C port must support DP Alt Mode. -
Deliver Professional Presentations
The presentation remote features a sleek, ergonomic design with a wireless range of 90 feet (27 m) and includes the required batteries and a carrying case. The USB receiver is supported by generic HID drivers, ensuring it will work with virtually any Mac or Windows computer. With a built-in laser pointer, the presentation remote lets you guide your audience's attention to critical information in your on-screen content. It's perfect for PowerPoint presentations, websites or any other visuals you want to share with an audience. The BNDDKTCHVPRS bundle is backed by a two-year StarTech.com warranty and free lifetime technical support. Our knowledgeable Technical Advisory Team is multilingual and located at our head office.
- StarTech.com USB-C Multiport Adapter with Wireless Presenter Remote - Ethernet - Portable Laptop Docking Station Bundle (BNDDKTCHVPRS) - docking station - USB-C - VGA, HDMI - GigE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- VGA, HDMI
- 5.4 cm x 11.4 cm x 1.7 cm
- 192 g
- Black
- Networking
- Gigabit Ethernet
- Power
- Power Provided
- 3-year warranty
- Product Type
- Docking station
- 5.4 cm
- 11.4 cm
- 1.7 cm
- 192 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 3840 x 2160 - 30 Hz (HDMI only) , 2048 x 1280 - 30 Hz (VGA only)
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
- Input Device
- Remote control
- Cables Included
- 1 x USB-C cable - integrated
- USB powered, DisplayPort Alt Mode, auto MDIX support
- FCC, RoHS, REACH
- OS Required
- Google Chrome OS, Apple MacOS X 10.10 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
- Limited warranty - 3 years
- Shipping Weight
- 300 g
- 5 °C
- 35 °C
StarTech.com USB-C Multifunction Adapter | In Stock | £47.42 |
StarTech.com USB-C to 4K HDMI Adapter with Power Delivery | In Stock | £45.81 |
StarTech.com USB-C to VGA Adapter with PD | In Stock | £12.06 |
StarTech.com USB-C to 4K HDMI Adapter w/ PD | In Stock | £20.98 |
StarTech.com USB-C Adapter - PD - Silver | In Stock | £47.42 |
StarTech.com USB-C Multiport Adapter - DVI | In Stock | £17.11 |
