StarTech.com USB-C Multiport Adapter - DVI
Quicklinx: CX8TWS00 Mfr#: DKT30CDVPD
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: White
£23.31 ex VAT
£27.97 inc VAT
Charge your laptop through USB-C and create a workstation wherever you go, with DVI video output, Gigabit Ethernet and a USB-A port. Expand the connectivity of your USB-C enabled laptop. This sleek USB-C multiport adapter lets you create a powerful workstation virtually anywhere, providing DVI video output, one USB 3.0 Type-A port, and a Gigabit Ethernet port.
You can also power both the multiport adapter and your laptop simultaneously, with support for USB Power Delivery 2.0. It's the ideal accessory for your Dell XPS, MacBook Pro or other USB Type-C equipped laptop, and it's also Thunderbolt 3 port compatible.
The multiport adapter expands the connectivity of your port-limited laptop, using the built-in USB-C cable to connect to multiple devices simultaneously. When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. Connect to a DVI display in an office workspace or your home office with ease.
The Gigabit Ethernet port ensures reliable wired network access, plus with an additional USB 3.0 Type-A port, you can connect an existing peripheral device, like your mouse or flash drive.
The Gigabit Ethernet port ensures reliable wired network access, ideal for areas with limited Wi-Fi availability.
This compact multiport adapter is USB-powered, so there's no need to carry a separate power adapter with you. Ideal for mobile use from office to home, or for travel, the multiport adapter features a USB-C port that supports USB Power Delivery 2.0 so you can power and charge your laptop as you work. The adapter features a built-in USB-C cable and gives you network connectivity plus a USB Type-A connection for optimum versatility as you travel.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
  • All the Connections You Need
    The versatile adapter combines the performance of three single-function adapters into one powerful solution. • USB-C to DVI adapter • USB-C Ethernet adapter • USB-C to USB -A adapter Add a second display through the DVI port. Get fast, reliable network access through the Gigabit Ethernet RJ45 port and connect a USB 3.0 peripheral device, such as a mouse or USB flash drive, all with one, simple-to-use device.
  • Charge and Power Your Laptop While You Work
    The multiport adapter's USB-C port supports 60 W USB Power Delivery 2.0, so you can power and charge your laptop while you work.
  • Bring Productivity Wherever You Go
    The USB Type-C multiport adapter is highly portable and features an integrated USB-C cable and USB-powered performance, so there's no need to carry a separate power adapter with you.
  • The StarTech.com Advantage for Docking Stations
    • Maximum compatibility - StarTech.com has a docking station to fit every operating system, laptop brand, and connectivity need •Text | Get more done faster - More ports and more displays maximize end user connectivity and productivity •Text | Quick installation - eliminate deployment headaches that waste time and frustrate end users •Text | IT Grade quality - trusted by IT pros around the world for our rigorous in-house product testing, robust compliance, and lifetime multilingual technical support The DKT30CDVPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
StarTech.com USB C Multiport Adapter, USB-C to DVI-D (Digital) Video Adapter with 60W Power Delivery Passthrough Charging, GbE, USB-A, Portable USB Type-C/Thunderbolt 3 Mini Laptop Dock - Dock with Ethernet (DKT30CDVPD) - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
Interfaces Details
Network (RJ-45) , DVI-I (female connector) , USB 3.0 (female connector) , USB-C (power only) (female connector) , USB-C (male connector)
4.1 cm x 9.7 cm x 1.7 cm
Enclosure Colour
White
3-year warranty
Bus Type
USB-C
Max Resolution
1920 x 1200
Interfaces Details
HD/4k Ready
Video Input
USB powered
Microsoft Windows 7 / 8.1 / 10 / 11, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Google Chrome OS
1 x USB-C cable
FCC, RoHS, WEEE
4.1 cm
9.7 cm
1.7 cm
48.7 g
Enclosure Colour
White
Limited warranty - 3 years
45 °C
0 - 85% (non-condensing)
CX8T StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
CX8T StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £57.25
CX8T StarTech.com USB-C Multifunction Adapter In Stock £47.42
CX8T StarTech.com USB-C to VGA Adapter with PD In Stock £12.06
CX8T StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.98
CX8T StarTech.com USB-C Adapter - PD - Silver In Stock £47.42
CX8T StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £26.75
CX8T StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB In Stock £38.47
CX8T StarTech.com USB-C Adapter with HDMI & VGA In Stock £30.74
CX8T StarTech.com USB-C Multiport Adapter, 4K HDMI or VGA, Type-C Mini Dock In Stock £61.74
CX8T StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock In Stock £23.84
CX8T StarTech.com USB C Multiport Adapter 4K In Stock £32.06
CX8T StarTech.com USBC Multiport Adapter 4K HDMI In Stock £24.65
CX8T StarTech.com USB C Multiport Adapter PD, 4K In Stock £20.67
CX8T StarTech.com USB-C Multiport Adapter HDMI In Stock £53.20
CX8T StarTech.com Multiport Adapter HDMI/VGA In Stock £20.09
CX8T StarTech.com USB C Multiport Adapter 4K In Stock £23.49
CX8T StarTech.com USB C Mini Dock 4K HDMI In Stock £44.80
CX8T StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £33.64
CX8T StarTech.com USB C Multiport Adapter 2 HDMI In Stock £66.65
CX8T StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £30.58
CX8T StarTech.com USB-C Multiport Adapter In Stock £22.01
CX8T StarTech.com USB C Multiport Adapter In Stock £84.39
CX8T StarTech.com USB-C Multiport Adapter, HDMI In Stock £28.98
CX8T StarTech.com USB-C Multiport Adapter, HDMI In Stock £25.65
CX8T StarTech.com USB-C Triple Monitor Docking Station In Stock £148.72
CX8T StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £43.75
CX8T StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £28.18
CX8T StarTech.com USB-C Speakerphone Dock In Stock £80.38
CX8T StarTech.com USB-C Triple-Monitor Adapter In Stock £78.42
CX8T StarTech.com USB-C/USB-A Multiport Adapter In Stock £47.68
CX8T StarTech.com USB-C Triple-Monitor Adapter In Stock £82.13
Device Type: Laptop
Colour: White
