StarTech.com USB-C Adapter - PD -  Silver
Quicklinx: CTW5WS00 Mfr#: DKT30CHPDW
45 In Stock
£45.56 ex VAT
£54.67 inc VAT
Power and charge your laptop through USB Type-C (5Gbps), and create a workstation virtually anywhere you go, adding 4K video, GbE, and two USB 3.0 ports. Expand the connectivity of your USB-C enabled laptop. This sleek and compact USB-C multiport adapter, in attractive silver and white, is the perfect accessory for your MacBook Pro, MacBook, Chromebook or other USB Type C equipped laptop. The adapter is also Thunderbolt 3 data port compatible, so you can connect it to your Thunderbolt 3 equipped laptop.
The USB-C adapter lets you create a powerful workstation virtually anywhere, providing 4K Ultra HD (3840 x 2160p) HDMI video output, two USB 3.0 ports, and a Gigabit Ethernet port. You can also power both the multiport adapter and your laptop simultaneously, with support for USB Power Delivery 2.0.
When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. It offers a 4K HDMI port (with audio), so you can easily connect a high-resolution monitor and gain access to more screen space. With higher resolutions, you can view more windows at once and increase your productivity.
The Gigabit Ethernet port ensures reliable wired network access, which is ideal for areas with limited Wi-Fi access. Plus, with two additional USB 3.0 ports (USB Type-A) you can connect your existing peripheral devices, like your mouse or flash drive.
This multiport adapter means you don't have to carry multiple power adapters with you. Ideal for mobile use, it features a USB-C port that supports USB Power Delivery 2.0 (USB PD 2.0), so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter.
The versatile multiport adapter is compact and lightweight, so it's easy to tuck into your laptop bag. It consolidates multiple ports into a single adapter, which means you don't need to bring along multiple single-function adapters.
The adapter also features an integrated USB-C cable, which means one less cable to carry with you. The cable's extended length at 348 mm (13.7"), provides you with more placement options, so you can position the adapter exactly where you need it, to work in comfort.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP alt mode.
  • Create a Powerful Workstation
    The versatile USB-C adapter lets you create a dual-monitor workstation virtually anywhere, providing 4K Ultra HD (3840 x 2160p) HDMI output with 30 Hz refresh rate and audio, two USB 3.0 ports, and a Gigabit Ethernet port, with support for USB Power Delivery 2.0. The Gigabit Ethernet port with support for Wake-on-LAN (WOL), jumbo frames, VLAN tagging, and Energy-Efficient Ethernet, delivers a reliable wired network connection, ideal for areas with limited Wi-Fi access. Plus, with two additional USB 3.0 ports (USB Type-A) you can connect productivity devices like your mouse and/or flash drive.
  • Designed for Easy Portability
    Ideal for mobile use, the compact multiport adapter supports USB Power Delivery 2.0 (PD 2.0), so you can use your laptop's USB-C power adapter to power both your laptop and the adapter. The adapter also features an integrated extended-length USB-C cable, for added flexibility in connecting to your laptop, which means one less cable to carry with you.
  • The StarTech.com Advantage for Docking Stations
    • Maximum compatibility - StarTech.com has a docking station to fit every operating system, laptop brand, and connectivity need •Text | Get more done faster - More ports and more displays maximize end user connectivity and productivity •Text | Quick installation - eliminate deployment headaches that waste time and frustrate end users •Text | IT Grade quality - trusted by IT pros around the world for our rigorous in-house product testing, robust compliance, and lifetime multilingual technical support The DKT30CHPDW is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP alt mode.
StarTech.com USB-C Multiport Adapter, USB-C Travel Docking Station with 4K HDMI, 60W Power Delivery Pass-Through, GbE, 2pt USB-A 3.0 Hub, Portable Mini USB Type-C Dock for Laptop, White - Portable USB-C Dock (DKT30CHPDW) - docking station - USB-C / Thunderbolt 3 - HDMI - 1GbE - TAA Compliant
Docking station
Docking Interface
Video Interfaces
HDMI
5.1 cm x 9.6 cm x 1.6 cm
64 g
White, silver
Gigabit Ethernet
TAA Compliant
3-year warranty
Docking station
5.1 cm
9.6 cm
1.6 cm
64 g
Enclosure Colour
White, silver
Video
Max Resolution Details
4096 x 2160 - 24 Hz , 3840 x 2160 - 30 Hz
Gigabit Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1, Power Delivery 2.0
1 x USB-C 3.1 Gen 1 with Power Delivery (60W) - 24 pin USB-C , 1 x display / video - HDMI - 19 pin HDMI Type A , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C cable - integrated - 25 cm
Wake on LAN, USB powered, full duplex support, DisplayPort Alt Mode, auto MDIX support, 60W power delivery, plastic housing
FCC, RoHS, UASP (USB Attached SCSI Protocol)
TAA Compliant
Google Chrome OS, Apple MacOS X 10.9 - 10.15, Apple MacOS X 11.3 or later, Microsoft Windows 7 / 8 / 8.1 / 10 / 11
Limited warranty - 3 years
Shipping Width
14.7 cm
Shipping Depth
21.3 cm
Shipping Height
4.2 cm
Shipping Weight
193 g
CTW5 StarTech.com USB-C Multifunction Adapter In Stock £45.56
CTW5 StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £44.69
CTW5 StarTech.com USB-C to VGA Adapter with PD In Stock £12.06
CTW5 StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.15
CTW5 StarTech.com USB-C Adapter - PD - Silver In Stock £45.56
CTW5 StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £14.81
CTW5 StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.00
CTW5 StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.23
CTW5 StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £25.41
CTW5 StarTech.com USB-C Multiport Adapter - DVI In Stock £24.59
CTW5 StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock In Stock £22.64
CTW5 StarTech.com USB C Multiport Adapter 4K In Stock £30.80
CTW5 StarTech.com USBC Multiport Adapter 4K HDMI In Stock £26.01
CTW5 StarTech.com USB C Multiport Adapter PD, 4K In Stock £20.89
CTW5 StarTech.com USB C Multiport Adapter In Stock £16.61
CTW5 StarTech.com USB C Multiport Adapter, 4K In Stock £31.73
CTW5 StarTech.com USB C Multiport Adapter 4K In Stock £25.41
CTW5 StarTech.com USB C Mini Dock 4K HDMI In Stock £41.49
CTW5 StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £32.31
CTW5 StarTech.com USB C Multiport Adapter 2 HDMI In Stock £63.28
CTW5 StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £29.36
CTW5 StarTech.com USB-C Multiport Adapter In Stock £22.04
CTW5 StarTech.com USB C Multiport Adapter In Stock £80.74
CTW5 StarTech.com USB-C Multiport Adapter, HDMI In Stock £31.34
CTW5 StarTech.com USB-C Multiport Adapter, HDMI In Stock £29.25
CTW5 StarTech.com USB-C Triple Monitor Docking Station In Stock £142.84
CTW5 StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £42.02
CTW5 StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £26.76
CTW5 StarTech.com USB-C Speakerphone Dock In Stock £76.92
