Connect this USB Type-C Multiport Adapter to a USB-C, USB4, or Thunderbolt 3/4 laptop to enable single-display HDMI 2.0b or DisplayPort 1.4 video output via DP Alt Mode, supporting resolutions up to 4K 60Hz. The USB-C dock works with USB Type-C laptops or tablets, such as a Chromebook, Dell XPS, or MacBook. It features a 3-Port USB 3.2 Gen 2 (10Gbps) Hub (2x USB-A, 1x USB-C), and Gigabit Ethernet. Connect the laptop USB-C power supply to the dedicated USB Power Delivery (PD) 3.0 port, to charge the laptop.
Extra-Long Cable with Built-in Cable Manager
The Multiport Adapter features an extra-long attached 12.6in. (32cm) USB-C host cable. The Thermoplastic Elastomer (TPE) cable jacket is softer and more flexible than PVC jacketed cables. The extra-long cable reduces port/connector strain, particularly when laptops are placed on riser stands, or on 2-in-1 devices with raised USB-C ports, such as the Microsoft Surface. In addition, the Multiport Adapter also features an innovative wrap-around cable manager that facilitates tangle-free storage in a laptop bag. -
USB 3.2 Gen 2 Hub
Connect one USB-C and two USB-A peripherals to the USB 3.2 Gen 2 (10Gbps) ports. A versatile solution for adding docking station capabilities in an office, home office, hotel, or in the boardroom. It's portable enough to be carried in a bag or backpack. This lightweight USB-C Adapter can operate with bus-power alone or connect a USB-C power adapter (not included with Multiport Adapter) for laptop charging. USB PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when disconnecting the power source. -
Wired Gigabit Network Connectivity
The Gigabit Ethernet port ensures reliable wired network access, with support for PXE Boot and Wake-on-LAN (WoL). -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : Setup and save custom windows layouts. •Text | MAC Address Pass-Through Utility : Improve network security. •Text | USB Event Monitoring Utility : Track and log connected USB devices. •Text | Wi-Fi Auto Switch Utility : Enable quick access to wired LAN.
- StarTech.com USB-C Multiport Adapter, 4K 60Hz HDMI/DP Video, 3-Port USB Hub, 100W Power Delivery Pass-Through, GbE, USB Type-C Travel Dock w/ Charging, 1ft/30cm Wrap-Around Cable - Mini Laptop Docking Station (DKT31CDHPD3) - docking station - USB-C - HDMI, DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- HDMI, DP
- 6.4 cm x 12.4 cm x 2.5 cm
- 130 g
- Space grey
- Networking
- Gigabit Ethernet
- Power
- Power adapter 16 Watt Power Provided
- 3-year warranty
- Product Type
- Docking station
- 6.4 cm
- 12.4 cm
- 2.5 cm
- 130 g
- Enclosure Colour
- Space grey
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- USB 3.2 Gen 2
- 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - DisplayPort - 20 pin DisplayPort , 2 x USB-C 3.2 Gen 2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C (power only) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x USB-C 3.2 Gen 2 cable - integrated - 30 cm
- Wake on LAN, Preboot Execution Environment (PXE) support, 2 LED indicators, full duplex support, DisplayPort Alt Mode, plastic housing, 100W power delivery (pass-through), up to 10Gbps data transfer, 84W charging
- RoHS, WEEE, RCM, DisplayPort 1.4
- Power Device
- Power adapter
- Power Provided
- 16 Watt
- OS Required
- Linux, Android, Google Chrome OS, Ubuntu 18.04, Apple macOS 10.15, Ubuntu 20.04, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 13.0, Apple macOS 11
- Limited warranty - 3 years
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 154 g
- 0 °C
- 50 °C
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.78 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £10.14 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.03 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.55 |
