StarTech.com USB C Multiport Video Adapter - Space Gray
Quicklinx: DXFTWS00 Mfr#: CDPVDHDMDPSG
Type: Docking
Colour: Space grey
19 in stock
£54.36 ex VAT
£65.23 inc VAT
Connect your laptop to an mDP, VGA or HDMI display with this space gray USB-C adapter. This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C or Thunderbolt 3 computer to a VGA, DVI, HDMI or Mini DisplayPort display.
Avoid the hassle of carrying different adapters for different displays with this 4-in-1 USB-C video adapter'. With VGA, DVI, HDMI and mDP output, you can connect your laptop to virtually any display. It's a convenient plug-and-play solution for travel or Bring Your Own Device (BYOD) applications, wherever you go.
The adapter features a built-in magnetic fastener that helps guide the breakout cable into place for quick and secure portability. With its durable aluminum enclosure, the adapter can withstand being carried around in any travel bag.
The HDMI and mDP outputs on this adapter support UHD 4K resolutions providing four times the picture quality of high-definition 1080p. All of the outputs (HDMI, mDP, VGA, DVI) can support high-definition resolutions of up to 1920 x 1200.
This USB-C adapter has an aluminum housing and built-in black USB-C cable designed to match your space gray MacBook. The adapter is compatible with any device that supports USB-C DP Alt Mode.
StarTech.com USB-C Multiport Video Adapter - 4-in-1 USBC Adapter Space Gray - external video adapter - space grey
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI output (female connector) , VGA (female connector) , Mini DisplayPort (female connector) , DVI-D (female connector)
5.4 cm 1.5 cm
Length
10.4 cm
Enclosure Colour
Space grey
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160
HD/4k Ready, 7.1 channel surround sound ready
1 x USB-C cable - 11.5 cm
FCC, RoHS, WEEE, DisplayPort 1.2
5.4 cm
1.5 cm
Length
10.4 cm
90 g
Shipping Weight
100 g
Enclosure Colour
Space grey
Limited warranty - 3 years
StarTech.com USB C Multiport Video Adapter - Space Gray Bundle deal on StarTech.com USB C Multiport Video Adapter - Space Gray
£153.53
DXFT StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £18.91
DXFT StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £32.61
DXFT StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £32.61
DXFT StarTech.com mDP to HDMI or VGA Converter In Stock £17.92
DXFT StarTech.com USB C Multiport Video Adapter – Aluminum – USB-C to VGA/HDMI/Mini DisplayPort/DVI Adapter –Display Adapter (CDPVGDVHDMDP) - external video adapter In Stock £52.98
DXFT StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £40.96
DXFT StarTech.com USB C Multiport Video Adapter - Rose Gold In Stock £54.36
DXFT StarTech.com USB C Multiport Video Adapter - Space Gray In Stock £54.36
Type: Docking
Colour: Space grey
Price Range Ex VAT: 50 - 100
