StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter
Quicklinx: 7RWYWS00 Mfr#: MDP2DPDVHD
£20.15 ex VAT
£24.18 inc VAT
Connect your mini DisplayPort Device to a DisplayPort, HDMI or DVI Display, with this Compact, All-in-One Adapter. The MDP2DPDVHD mini DisplayPort to DisplayPort, DVI or HDMI Multifunction Adapter converts a mini DisplayPort (mDP) input to DisplayPort, DVI or HDMI output signals - all in a single compact adapter. This multifunction adapter offers the unique ability to connect almost any display to your mini DisplayPort equipped PC or Mac, providing the perfect solution for business environments that have mixed display hardware - saving the expense of purchasing new displays for compatibility. A plug-and-play solution that requires no software or drivers, this versatile mDP adapter offers a quick and simple installation for the utmost convenience. Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
StarTech.com Travel A/V adapter - 3-in-1 Mini DisplayPort to DisplayPort DVI or HDMI converter (MDP2DPDVHD) - adapter - DisplayPort / HDMI / DVI - 15 cm
Cable
Adapter - DisplayPort / HDMI / DVI
Length
15 cm
Connectors
Mini DisplayPort - male
Connectors (Second End)
DVI-D - female , HDMI - female , DisplayPort - female
3-year warranty
Cable Type
Adapter
Interface Supported
Length
15 cm
Connectors
24+1 pin digital DVI - female , 19 pin HDMI Type A - female , 20 pin DisplayPort - female
Plug and Play, FCC, RoHS
Limited warranty - 3 years
7RWY StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £20.15
7RWY StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White In Stock £9.27
7RWY StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.48
7RWY StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.05
7RWY StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £8.95
7RWY StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £31.29
7RWY StarTech.com mDP to HDMI or VGA Converter In Stock £8.19
7RWY StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
7RWY StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Silver Aluminum Adapter - 4-in-1 USB-C Converter (CDPVGDVHDMDP) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £22.46
7RWY StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £11.55
