Connect a Mini DisplayPort-equipped PC or Mac to an HDMI, VGA, or DVI Display. This travel adapter lets you connect your mDP enabled Ultrabook or laptop computer to any VGA or HDMI display. The 3-in-1 Mini DisplayPort adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3 Surface Pro 2 or Surface Book.
Why carry multiple adapters when you only need one? Instead of keeping three different adapters on-hand, the mDP travel adapter offers VGA, DVI and HDMI outputs, so you'll be able to connect from your laptop mDP output to any modern boardroom or classroom display - an ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports video resolutions up to 1920x1200 or 1080p you can convert a Mini DisplayPort video source to HDMI, VGA or DVI without sacrificing video quality.
The travel A/V adapter maximizes portability with a small footprint and lightweight design. The convenient design ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter. With this adapter you can walk into virtually any boardroom ready to present, making a great first impression, and saving you the embarrassment of having to rummage through your bag looking for the right connector.
The 3-in-1 converter is compatible with the Intel Thunderbolt port on your computer and installs easily with no software or drivers required.
- StarTech.com 3 in 1 Mini DisplayPort Adapter - 1080p - Mini DP / Thunderbolt to HDMI / VGA / DVI Splitter for Your Monitor (MDP2VGDVHD) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 27 cm
- Cable
- Adapter - Mini DisplayPort / HDMI / DVI / VGA
- Max Output Resolution
- 1920 x 1200
- Length
- 27 cm
- Black
- Connectors
- Mini DisplayPort - male
- Connectors (Second End)
- HDMI - female , HD-15 (VGA) - female , DVI-D - female
- Displayport 1.2/Thunderbolt
- Active adapter, 1920 x 1200 (WUXGA) support
- 3-year warranty
- Designed For
- P/N: DKT31CMDPHPD
- Cable Type
- Adapter active, 1920 x 1200 (WUXGA) support
- Interface Supported
- Length
- 27 cm
- 7.1 channel Surround Sound
- Black
Adapters & Converters
- 1920 x 1200
- Connectors
- 19 pin HDMI Type A - female , 15 pin HD D-Sub (HD-15) - female , 24+1 pin digital DVI - female
- FCC, RoHS
- 4.5 cm
- 1.5 cm
- 57 g
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.8 cm
- Shipping Weight
- 66 g
- Limited warranty - 3 years
- Designed For
- P/N: DKT31CMDPHPD
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter | In Stock | £21.24 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White | In Stock | £10.15 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.63 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.95 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £7.58 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black | In Stock | £32.99 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £18.32 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £13.32 |
StarTech.com DisplayPort to HDMI VGA Adapter - 4K 60Hz - Multiport Video | In Stock | £22.14 |
