StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White
Quicklinx: 81T6WS00 Mfr#: MDP2HDW
£10.56 ex VAT
£12.67 inc VAT
Connect an HDMI -capable display to a Mini-DisplayPort -equipped PC or Mac computer. The MDP2HDW passive Mini DisplayPort to HDMI Video Adapter/Converter (White) offers a convenient HDMI/Mini-DisplayPort link, which enables you to connect an HDMI computer monitor or television to a device with a Mini-DisplayPort output, while saving the expense of upgrading the monitor for compatibility.
The adapter supports high resolution output up to 1920x1200, offering a high quality solution for mirroring or extending a computer desktop onto a second display.
This versatile Mini DisplayPort to HDMI adapter requires a multimode DisplayPort port (DisplayPort ++) connection to function, and is compatible with Intel Thunderbolt output when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
StarTech.com Mini DisplayPort® to HDMI® Video Adapter Converter 1920x1200 - White Mini DP to HDMI Adapter M/F (MDP2HDW) - adapter - DisplayPort / HDMI - 17 cm
Cable
Adapter - DisplayPort / HDMI
Length
17 cm
White
Connector
Mini DisplayPort - male
Connector (Second End)
HDMI - female
3-year warranty
Cable Type
Adapter
Interface Supported
DisplayPort / HDMI
Length
17 cm
White
Connector
19 pin HDMI Type A - female
FCC, RoHS
Limited warranty - 3 years
81T6 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.52
81T6 StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £11.81
81T6 StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £22.81
81T6 StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White In Stock £10.56
81T6 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.66
81T6 StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.02
81T6 StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £7.69
81T6 StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £35.22
81T6 StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £23.82
81T6 StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £18.39
81T6 StarTech.com mDP to HDMI or VGA Converter In Stock £19.83
81T6 StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
81T6 StarTech.com DP to HDMI or VGA Converter In Stock £19.05
81T6 StarTech.com Mini DisplayPort to HDMI Adapter - 1080p In Stock £11.81
