StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter
Quicklinx: 95QDWS00 Mfr#: MDP2VGDVHD
£9.27 ex VAT
£11.12 inc VAT
Connect a Mini DisplayPort-equipped PC or Mac to an HDMI, VGA, or DVI Display. This travel adapter lets you connect your mDP enabled Ultrabook or laptop computer to any VGA or HDMI display. The 3-in-1 Mini DisplayPort adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3 Surface Pro 2 or Surface Book.
Why carry multiple adapters when you only need one? Instead of keeping three different adapters on-hand, the mDP travel adapter offers VGA, DVI and HDMI outputs, so you'll be able to connect from your laptop mDP output to any modern boardroom or classroom display - an ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports video resolutions up to 1920x1200 or 1080p you can convert a Mini DisplayPort video source to HDMI, VGA or DVI without sacrificing video quality.
The travel A/V adapter maximizes portability with a small footprint and lightweight design. The convenient design ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter. With this adapter you can walk into virtually any boardroom ready to present, making a great first impression, and saving you the embarrassment of having to rummage through your bag looking for the right connector.
The 3-in-1 converter is compatible with the Intel Thunderbolt port on your computer and installs easily with no software or drivers required.
StarTech.com 3 in 1 Mini DisplayPort Adapter - 1080p - Mini DP / Thunderbolt to HDMI / VGA / DVI Splitter for Your Monitor (MDP2VGDVHD) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 27 cm
Cable
Adapter - Mini DisplayPort / HDMI / DVI / VGA
Max Output Resolution
1920 x 1200
Length
27 cm
Connectors
Mini DisplayPort - male
Connectors (Second End)
HDMI - female , HD-15 (VGA) - female , DVI-D - female
Displayport 1.2/Thunderbolt
Active adapter, 1920 x 1200 (WUXGA) support
3-year warranty
P/N: DKT31CMDPHPD
Cable Type
Adapter active, 1920 x 1200 (WUXGA) support
Interface Supported
Length
27 cm
7.1 channel Surround Sound
Adapters & Converters
1920 x 1200
Connectors
19 pin HDMI Type A - female , 15 pin HD D-Sub (HD-15) - female , 24+1 pin digital DVI - female
FCC, RoHS
4.5 cm
1.5 cm
57 g
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.8 cm
Shipping Weight
66 g
Limited warranty - 3 years
P/N: DKT31CMDPHPD
95QD StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £20.33
95QD StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White In Stock £9.42
95QD StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
95QD StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.78
95QD StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £9.27
95QD StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £31.58
95QD StarTech.com mDP to HDMI or VGA Converter In Stock £8.35
95QD StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
95QD StarTech.com DP to HDMI or VGA Converter In Stock £16.54
95QD StarTech.com Startech USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Silver Aluminum Adapter - 4-in-1 USB-C Converter (CDPVGDVHDMDP) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £20.82
95QD StarTech.com DisplayPort to HDMI VGA Adapter - 4K 60Hz - Multiport Video In Stock £20.99
