StarTech.com USB 3 Fiber Converter Open SFP
Quicklinx: DFR7WS00 Mfr#: US1GA30SFP
More than 50 In Stock
£204.47 ex VAT
£245.36 inc VAT
1GbE USB 3.0 TO FIBER OPTIC CONVERTER: For USB-A enabled computers who require occasional access to a fiber LAN, for laptop users who don't have the option of an internal fiber network card.
TECH SPECS: Gigabit 1000Mbps | 1x Open SFP (MSA compliant) | Realtek RTL8153-VC-CG | 1x USB 3.0 Type A | Multi-mode (MMF) & Single mode (SMF) Fiber Comp.| 9K Jumbo Frames | VLAN | USB Bus Powered.
MAXIMUM PORTABILITY: Compact, lightweight, and cableless design make this USB NIC / Gigabit Network Adapter easy to securely connect your Laptop to a Gigabit Ethernet Network wherever you go.
FLEXIBLE OPEN SFP SLOT: Use any MSA compliant SFP module; beneficial for network admins, installation technicians, and those who require seamless access to different types of fiber connectivity.
THE STARTECH.COM ADVANTAGE: StarTech.com offers a 2-year warranty on this USB-A to Gigabit Ethernet Adapter and free lifetime 24/5 multilingual technical support based in North America.
CONNECTIVITY TOOLS: Provided with this device, the application improves performance and security, featuring MAC Address Changer & Wi-Fi Auto Switch utilities.
  • A flexible solution with an open SFP slot
    The open SFP slot enables you to use your preferred SFP transceiver module to meet your networking needs - use an SFP with your desired wavelength, distance, and connection type to achieve an efficient network solution. (SFP sold separately.)
  • Secure fiber-to-the-desk connectivity
    This USB to fiber-optic converter provides reliable fiber connectivity while protecting your network from problems with electronic interference - a common issue with copper Ethernet networks. Fiber-to-the-desk connectivity (FTTD) maximizes network security, reducing the risk of data leaks for sensitive information, without compromising network speed and reliability.
  • Easy portability
    Compact and portable, this USB 3.0 to fiber-optic converter is powered directly from the USB port.
  • Plug and play
    Get up and running quickly. The USB to fiber-optic converter supports certified drivers for Windows, Mac and Linux . Once the adapter is plugged into a USB port, you simply install the drivers and the adapter is ready to transmit over a fiber network.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Mac Address Pass-Through Utility : To improve network security. •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB 3.0 to Fiber Optic Converter, Compact USB to Open SFP Adapter, USB to Gigabit Network Adapter, USB 3.0 Fiber Adapter Multi Mode(MMF)/Single Mode Fiber (SMF) Compatible - USB Ethernet adapter (US1GA30SFP) - network adapter - USB 3.0 - 1000Base-LX/1000Base-SX x 1
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
5.5 cm 2 cm
Length
26 cm
100 g
Cabling Type
Ethernet 1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
Jumbo frame size: 9000
IEEE 802.3z, IEEE 802.1Q
Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux 3.5 to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.9 - 10.14, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Status Indicators
Power, link/activity
Full duplex capability, USB powered, Jumbo Frames support, plastic housing
1 x 1000Base-LX/SX - SFP (mini-GBIC) - female
1 x USB cable (integrated) - 19.5 cm
FCC, RoHS, WEEE
5.5 cm
2 cm
Length
26 cm
100 g
Shipping Weight
120 g
60 °C
5 - 90%
