1GbE USB 3.0 TO FIBER OPTIC CONVERTER: For USB-A enabled computers who require occasional access to a fiber LAN, for laptop users who don't have the option of an internal fiber network card.
TECH SPECS: Gigabit 1000Mbps | 1x Open SFP (MSA compliant) | Realtek RTL8153-VC-CG | 1x USB 3.0 Type A | Multi-mode (MMF) & Single mode (SMF) Fiber Comp.| 9K Jumbo Frames | VLAN | USB Bus Powered.
MAXIMUM PORTABILITY: Compact, lightweight, and cableless design make this USB NIC / Gigabit Network Adapter easy to securely connect your Laptop to a Gigabit Ethernet Network wherever you go.
FLEXIBLE OPEN SFP SLOT: Use any MSA compliant SFP module; beneficial for network admins, installation technicians, and those who require seamless access to different types of fiber connectivity.
THE STARTECH.COM ADVANTAGE: StarTech.com offers a 2-year warranty on this USB-A to Gigabit Ethernet Adapter and free lifetime 24/5 multilingual technical support based in North America.
CONNECTIVITY TOOLS: Provided with this device, the application improves performance and security, featuring MAC Address Changer & Wi-Fi Auto Switch utilities.
A flexible solution with an open SFP slot
The open SFP slot enables you to use your preferred SFP transceiver module to meet your networking needs - use an SFP with your desired wavelength, distance, and connection type to achieve an efficient network solution. (SFP sold separately.) -
Secure fiber-to-the-desk connectivity
This USB to fiber-optic converter provides reliable fiber connectivity while protecting your network from problems with electronic interference - a common issue with copper Ethernet networks. Fiber-to-the-desk connectivity (FTTD) maximizes network security, reducing the risk of data leaks for sensitive information, without compromising network speed and reliability. -
Easy portability
Compact and portable, this USB 3.0 to fiber-optic converter is powered directly from the USB port. -
Plug and play
Get up and running quickly. The USB to fiber-optic converter supports certified drivers for Windows, Mac and Linux . Once the adapter is plugged into a USB port, you simply install the drivers and the adapter is ready to transmit over a fiber network. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Mac Address Pass-Through Utility : To improve network security. •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com USB 3.0 to Fiber Optic Converter, Compact USB to Open SFP Adapter, USB to Gigabit Network Adapter, USB 3.0 Fiber Adapter Multi Mode(MMF)/Single Mode Fiber (SMF) Compatible - USB Ethernet adapter (US1GA30SFP) - network adapter - USB 3.0 - 1000Base-LX/1000Base-SX x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- 5.5 cm 2 cm
- Length
- 26 cm
- 100 g
- Cabling Type
- Ethernet 1000Base-SX
- Data Link Protocol
- 1GbE
- Data Transfer Rate
- 1 Gbps
- Capacity
- Jumbo frame size: 9000
- IEEE 802.3z, IEEE 802.1Q
- Black
- System Requirements
- Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux 3.5 to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.9 - 10.14, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Gigabit Ethernet
- 1 Gbps
- Capacity
- Status Indicators
- Power, link/activity
- Full duplex capability, USB powered, Jumbo Frames support, plastic housing
- 1 x 1000Base-LX/SX - SFP (mini-GBIC) - female
- Cables Included
- 1 x USB cable (integrated) - 19.5 cm
- FCC, RoHS, WEEE
- Black
- OS Required
- 5.5 cm
- 2 cm
- Length
- 26 cm
- 100 g
- Shipping Weight
- 120 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 90%
StarTech.com 3m Multimode 62.5/125 Duplex Fiber Patch Cable LC - SC | In Stock | £16.24 |
StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps | In Stock | £152.48 |
StarTech.com Fiber Media Converter - w/ SFP | In Stock | £67.70 |
StarTech.com 1000Base-LX SFP - SM LC- 10 km | In Stock | £39.33 |
StarTech.com 1000Base-SX SFP - MM LC- 550 m | In Stock | £22.95 |
StarTech.com USB 3 Fiber Converter Open SFP | In Stock | £162.25 |
StarTech.com USB 2.0 to Fiber Converter | In Stock | £134.90 |
StarTech.com USB C to Fiber Optic Converter | In Stock | £185.15 |
