StarTech.com USB 3.1 Enclosure for 2.5" SSD
Quicklinx: BFPBWS00 Mfr#: S251BMU313
Type: Storage enclosure
HD Size: 2.5
Power Supply: [N/A]
10 In Stock
£25.78 ex VAT
£30.93 inc VAT
Get ready for ultra-fast USB 3.1 Gen 2 data storage using your 2.5" SSD or HDD. Now, access your data in record time with the superior performance of USB 3.1 Gen 2 (10 Gbps). This single-drive enclosure gives you a powerful external storage solution.
The enclosure turns your 2.5in SATA solid-state or hard drive into ultra-fast, ultra portable data storage. Its lightweight, compact design allows it to be tucked easily into a laptop bag or carrying case. Engineered with a durable and sleek brushed aluminum housing, it's equipped to keep your data safe and secure wherever you go.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
The enclosure connects easily to a host computer through USB 3.1 Gen 2, with no external power required. It is equipped with a USB A to Micro B cable, providing backward compatibility with existing USB ports or hardware. It also provides UASP support for enhanced performance.
StarTech.com USB 3.1 (10 Gbps) Gen 2 External Hard Drive Enclosure for 2.5" SATA Drives - Portable Hard Drive Enclosure (S251BMU313) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
Hard drive, solid state drive
Product Material
Aluminium
Power Source
Included AC adapter
AC 120/230 V
11.54 cm x 19.15 cm x 3.14 cm
320 g
P/N: BNDTBUSB3142, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2
2.5"
Host Bus
USB 3.1 (Gen 2)
Product Material
Aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
ASMedia ASM1351
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
Stand, screwdriver, 4 x screws
1 x USB cable - external
LED indicator, UASP transfer protocol, tested with up to 2TB 7200 RPM 2.5" hard drives
FCC, RoHS
Power Source
Included AC adapter
Power adapter
AC 120/230 V
11.54 cm
19.15 cm
3.14 cm
320 g
10 - 95%
BFPB StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £7.36
BFPB StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.43
BFPB StarTech.com Rugged Hard Drive Enclosure In Stock £32.20
BFPB StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £25.78
BFPB StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £52.38
BFPB StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £80.75
BFPB StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £16.51
BFPB StarTech.com M.2 SATA Enclosure with USB-C In Stock £25.64
BFPB StarTech.com USB 3.1 2.5/3.5" SATA Adapter In Stock £26.81
BFPB StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £52.74
BFPB StarTech.com Dual M.2 Enclosure - RAID In Stock £41.89
BFPB StarTech.com USB C to SATA Adapter Cable In Stock £34.51
BFPB StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 In Stock £29.06
BFPB StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £37.70
BFPB StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA In Stock £48.05
HD Size: 2.5
Power Supply: [N/A]
