StarTech.com M.2 SATA Enclosure with USB-C
Quicklinx: C194WS00 Mfr#: SM21BMU31C3
Type: Storage enclosure
HD Size: M.2
Power Supply: [N/A]
£25.86 ex VAT
£31.03 inc VAT
Turn your M.2 NGFF SATA drive into an ultra-fast, ultra-portable storage solution for USB-C enabled devices. This compact M.2 SSD enclosure lets you add highly portable data storage to any laptop or computer with a USB-C port - such as MacBook, Chromebook Pixel, Dell XPS laptops, and many others. It turns your SATA M.2 drive into a high-speed storage solution over a USB 3.1 Gen 2 connection, at up to 10Gbps throughput.
This slim, pocket-sized M.2 NGFF SSD enclosure has been specially designed for mobility, with a small form factor design that fits easily into your laptop bag. Its lightweight yet durable aluminum housing helps to ensure your drive won't be damaged while you're on the move.
Ventilation holes help to dissipate heat and help ensure an optimum operating temperature.
Leverage the speed of your M.2 NGFF SATA drive with this external enclosure. It delivers USB 3.1 Gen 2 data transfer speeds up to 10Gbps as well as UASP support, so you can achieve higher transfer speeds when you connect it to a UASP-enabled host computer.
The enclosure works with tablets, laptops and desktop computers and is compatible with hosts equipped with Thunderbolt 3 USB-C ports.
The enclosure is compatible with all of the common M.2 SSDs, and enables you to mount multiple drive lengths, including: 30mm (2230), 42mm (2242), 60mm (2260), and 80mm (2280).
  • Robust material construction
    The enclosure is made from aluminum, providing strength and durability to safeguard your SSD from physical damage.
  • Efficient data transfer capabilities
    With USB 3.1 Gen 2 technology, the enclosure allows for data transfer rates of up to 10 Gbps, ensuring quick access to files.
  • Effective cooling design
    Ventilation holes enhance airflow, cooling the drive during operation to maintain optimal performance and longevity.
  • Broad compatibility
    Designed for Mac users, supporting M.2 SSDs while ensuring seamless integration into existing setups.
  • User-friendly setup
    The Plug-and-Play functionality ensures easy installation without the need for additional drivers or software.
Startech M.2 SSD Enclosure for M.2 SATA SSDs - USB 3.1 (10Gbps) with USB-C Cable - External Enclosure for USB-C Host - Aluminum (SM21BMU31C3) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Black, silver
Expansion Bays
1 x internal - M.2
Hard Drive Form Factor Compatibility
M.2
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
8 cm x 1.2 cm x 9.85 cm
55 g
P/N: TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
M.2
Host Bus
USB 3.1 (Gen 2)
Product Material
Aluminium
Black, silver
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
1
ASMedia ASM1153
Bays
1 x internal - M.2
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 24 pin USB-C
Screwdriver, screws
1 x USB cable - external
USB powered, UASP transfer protocol, ventilation holes
FCC, RoHS
8 cm
1.2 cm
9.85 cm
55 g
10 - 90%
C194 StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.43
C194 StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
C194 StarTech.com M.2 SATA Enclosure with USB-C In Stock £25.86
C194 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
C194 StarTech.com 3PT M.2 SSD Card - PCIe 3.0 In Stock £28.55
C194 StarTech.com Dual M.2 Enclosure - RAID In Stock £42.94
C194 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £27.51
C194 StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C In Stock £40.35
C194 StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £132.24
C194 StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 In Stock £29.33
C194 StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance In Stock £64.63
C194 StarTech.com USB PCIE/SATA M.2 Enclosure In Stock £45.80
HD Size: M.2
Power Supply: [N/A]
