StarTech.com USB 3.1 Gen 2 Dual-bay Dock
Quicklinx: BHZ3WS00 Mfr#: SDOCK2U313
Type: Storage controller
HD Size: 3.5, 2.5
Power Supply: Power adapter
£84.45 ex VAT
£101.34 inc VAT
Dock two of your 2.5" and 3.5" SATA drives over high performance USB 3.1 Gen 2 with UASP. Get unprecedented performance and storage capacity with this USB 3.1 Gen 2 (10 Gbps) dual-drive docking station. It supports both 2.5" and 3.5" form factor solid-state and hard drives, with a high capacity storage capability of 12TB (6TB per drive).
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
It's never been easier to dock and swap drives from your desktop computer or laptop. Simply insert your drives into the top loading slot, with no tools or trays required. The HDD ejection button allows fast and simple drive removal.
The dual-drive docking station comes with a USB Type-A to B cable, providing backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. It also supports UASP for enhanced performance.
Extend the value of this hard drive docking station further with the addition of the SAT2IDEADP" text="SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5" or 3.5" IDE hard drive into a SATA hard drive dock.
  • Convenient compatibility
    The dual-drive docking station comes with a USB Type-A to B cable, providing backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. It also supports UASP for enhanced performance. Extend the value of this hard drive docking station further with the addition of our SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5" or 3.5" IDE hard drive into a SATA hard drive dock. The SDOCK2U313 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Dual-Bay USB 3.1 to SATA Hard Drive Docking Station, USB 3.1 (10 Gbps) Hard Drive Dock, External 2.53.5 SATA IIIIII, SSDHDD Docking Station, Hot-Swap Hard Drive Bay - Top-Loading - storage controller - USB 3.1 (Gen 2)
Storage controller - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
2 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
Data indicator, power indicator
Supported Devices
Hard drive, solid state drive
Product Material
Plastic
AC 120/230 V
14.8 cm x 13.2 cm x 7 cm
530 g
2.5", 3.5"
Host Bus
USB 3.1 (Gen 2)
Product Material
Plastic
Storage Controller
Supported Devices
ASMedia ASM1352R
Bays
2 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
1 x USB cable - external , 4 x power connector adaptor - external
LED indicator, tested with up to 6TB 7200 RPM hard drives, UASP transfer protocol
FCC, RoHS
Power adapter
AC 120/230 V
14.8 cm
13.2 cm
7 cm
530 g
5 °C
35 °C
20 - 80%
BHZ3 StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.90
BHZ3 StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.41
BHZ3 StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £84.45
BHZ3 StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £15.20
BHZ3 StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £19.09
BHZ3 StarTech.com USB 3.1 2.5/3.5" SATA Adapter In Stock £28.00
BHZ3 StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £55.00
BHZ3 StarTech.com USB C to SATA Adapter Cable In Stock £36.11
BHZ3 StarTech.com Dual-Bay SATA HDD/SSD Dock In Stock £51.79
BHZ3 StarTech.com 4 Bay SSD/HDD Docking Station In Stock £144.99
HD Size: 3.5
HD Size: 2.5
