StarTech.com USB 3.1 2.5/3.5" SATA Adapter
Quicklinx: C9WSWS00 Mfr#: USB312SAT3
18 In Stock
£28.14 ex VAT
£33.76 inc VAT
Easily access, transfer and backup data from a SATA drive to your PC or laptop, through USB 3.1. This USB 3.1 to SATA adapter gives you fast and easy access to the data on your 2.5 in./3.5 in. solid-state drives and hard drives. The adapter cable lets you connect your laptop or desktop computer directly to a SATA drive and access it through ultra-fast USB 3.1 Gen. 2 (up to 10Gbps).
This adapter cable lets you quickly swap your drives. You can copy or retrieve data from your 2.5 in. or 3.5 in. SATA drive, with no additional accessories required.
The tool-free adapter cable is ideal for IT technicians who need fast access to SATA drives. It's the perfect solution for data migration, drive cloning, and data backup or recovery applications, providing the fast performance of USB 3.1 Gen 2. You can also operate multiple adapters at the same time, when you require simultaneous access to many drives.
USB 3.1 Gen 2 gives you greater bandwidth and speed with rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
The compact, lightweight design of the USB 3.1 to SATA adapter provides easy portability. The adapter features an integrated 1 m cable, so you never to worry about forgetting to bring your connector cable with you.
You can connect easily to a 2.5 in. solid-state drive or hard drive, using USB power, with no external power required. A universal power adapter is included for use when connecting to your 3.5 in. drives or for any 2.5 in. drives that may require additional power.
StarTech.com USB to SATA Adapter Cable - 2.5in and 3.5in Drives - USB 3.1 - 10Gbps - External Hard Drive Cable - Hard Drive Adapter Cable (USB312SAT3) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage controller - external
Bus Type
USB 3.1 (Gen 2)
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
AC 120/230 V
2.45 cm x 8.5 cm x 2.1 cm
80 g
2.5", 3.5"
Host Bus
USB 3.1 (Gen 2)
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
ASMedia ASM1351
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 9 pin USB Type A
1 x USB cable - integrated
LED indicator, UASP transfer protocol
FCC, RoHS
Power adapter
AC 120/230 V
2.45 cm
8.5 cm
2.1 cm
80 g
60 °C
0 - 80%
C9WS StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.36
C9WS StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.56
C9WS StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £18.77
C9WS StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £19.56
C9WS StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £29.25
C9WS StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.41
C9WS StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £86.55
C9WS StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £15.34
C9WS StarTech.com USB 3.1 2.5/3.5" SATA Adapter In Stock £28.14
C9WS StarTech.com DC Power Adapter - 12V, 2A In Stock £12.61
C9WS StarTech.com USB C to SATA Adapter Cable In Stock £36.75
C9WS StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C In Stock £29.22
