StarTech.com USB C to SATA Adapter Cable
Quicklinx: CZDBWS00 Mfr#: USB31C2SAT3
Hurry, only 1 left in stock!
£34.82 ex VAT
£41.78 inc VAT
This USB-C to SATA adapter cable gives you fast and easy access to the data on your 2.5 in./3.5 in. solid-state drives and hard drives. The adapter cable lets you connect your USB-C enabled laptop or desktop computer directly to a SATA drive and access it through ultra-fast USB 3.1 Gen. 2 (up to 10Gbps). It's the ideal accessory for your Dell XPS, MacBook, Chromebook or other USB Type-C enabled device.
The USB-C to SATA adapter cable lets you quickly swap your drives. You can copy or retrieve data from your 2.5 in. or 3.5 in. SATA drive, with no additional accessories required.
The tool-free adapter cable is ideal for IT technicians who need fast access to SATA drives. It's the perfect solution for data migration, drive cloning, and data backup or recovery applications, providing the fast performance of USB 3.1 Gen 2. You can also operate multiple adapters at the same time, when you need simultaneous access to many drives.
USB 3.1 Gen 2 gives you greater bandwidth and speed, with rates of up to 10Gbps - twice the speed of USB 3.0 (also known as USB 3.1 Gen 1). It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
The compact, lightweight design of the USB-C to SATA adapter provides easy portability. The adapter features an integrated 1 m cable, so you never have to worry about forgetting to bring your connector cable with you.
You can connect easily to a 2.5 in. solid-state drive or hard drive, using USB power, with no external power required. A universal power adapter is included for use when connecting to your 3.5 in. drives or for any 2.5 in. drives that may require additional power.
  • Convenient and versatile drive access
    The USB-C to SATA adapter cable lets you quickly swap your drives. You can copy or retrieve data from your SATA drive, with no additional accessories required. The tool-free adapter cable is ideal for IT technicians who need fast access to SATA drives. It's the perfect solution for data migration, drive cloning, and data backup or recovery applications, providing the fast performance of USB 3.1 Gen 2. You can also operate multiple adapters at the same time, when you need simultaneous access to many drives.
  • Harness the speed of USB 3.1 Gen 2
    USB 3.1 Gen 2 gives you greater bandwidth and speed. It lets you leverage the high performance of the SSDs and hard drives, while alleviating bottlenecks in your data transfers.
  • Portable and easy to use
    The compact, lightweight design of the USB-C to SATA adapter provides easy portability. The adapter features an integrated cable, so you never have to worry about forgetting to bring your connector cable with you. You can connect easily to a solid-state drive or hard drive, using USB power, with no external power required.
StarTech.com USB C to SATA Adapter Cable - for 2.5 / 3.5" SATA Drives - 10Gbps - USB 3.1 - SATA to USB Adapter - External Hard Drive Cable (USB31C2SAT3) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage controller - external
Bus Type
USB 3.1 (Gen 2)
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
AC 120/230 V
2.5 cm x 8.7 cm x 2 cm
80 g
P/N: SVA12M2NEUA, SVA12M5NA
2.5", 3.5"
Host Bus
USB 3.1 (Gen 2)
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
ASMedia ASM1351
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 24 pin USB-C
1 x SuperSpeed USB-C cable - integrated - 1 m
LED indicator, UASP transfer protocol, S.M.A.R.T. support, TRIM support
FCC, RoHS, UASP (USB Attached SCSI Protocol)
Power adapter
AC 120/230 V
2.5 cm
8.7 cm
2 cm
80 g
60 °C
0 - 80%
CZDB StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
CZDB StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.36
CZDB StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
CZDB StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
CZDB StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.43
CZDB StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.68
CZDB StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £82.78
CZDB StarTech.com USB 3.1 2.5/3.5" SATA Adapter In Stock £27.05
CZDB StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
CZDB StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
CZDB StarTech.com USB C to SATA Adapter Cable In Stock £34.82
