Get ready for ultra-fast USB 3.1 Gen 2 data storage using your 2.5" SSD or HDD. Now, access your data in record time with the superior performance of USB 3.1 Gen 2 (10 Gbps). This single-drive enclosure gives you a powerful external storage solution.
The enclosure turns your 2.5in SATA solid-state or hard drive into ultra-fast, ultra portable data storage. Its lightweight, compact design allows it to be tucked easily into a laptop bag or carrying case. Engineered with a durable and sleek brushed aluminum housing, it's equipped to keep your data safe and secure wherever you go.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
The enclosure connects easily to a host computer through USB 3.1 Gen 2, with no external power required. It is equipped with a USB A to Micro B cable, providing backward compatibility with existing USB ports or hardware. It also provides UASP support for enhanced performance.
- StarTech.com USB 3.1 (10 Gbps) Gen 2 External Hard Drive Enclosure for 2.5" SATA Drives - Portable Hard Drive Enclosure (S251BMU313) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
- Storage enclosure - external
- Bus Type
- USB 3.1 (Gen 2)
- Black
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 10 GBps
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Aluminium
- Power Source
- Included AC adapter
- Power
- AC 120/230 V
- 11.54 cm x 19.15 cm x 3.14 cm
- 320 g
- 2-year warranty
- Designed For
- P/N: BNDTBUSB3142, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2
- 2.5"
- Host Bus
- USB 3.1 (Gen 2)
- Product Material
- Aluminium
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 10 GBps
- Supported Devices
- Processor
- ASMedia ASM1351
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
- Included Accessories
- Stand, screwdriver, 4 x screws
- Cables Included
- 1 x USB cable - external
- LED indicator, UASP transfer protocol, tested with up to 2TB 7200 RPM 2.5" hard drives
- FCC, RoHS
- Power Source
- Power adapter
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
- 11.54 cm
- 19.15 cm
- 3.14 cm
- 320 g
- 0 °C
- 40 °C
- 10 - 95%
- Designed For
StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M | In Stock | £7.53 |
StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £6.62 |
StarTech.com Rugged Hard Drive Enclosure | In Stock | £34.04 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £26.43 |
StarTech.com USB 3.1 Gen 2 Single-bay Dock | In Stock | £53.68 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £82.78 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £17.59 |
StarTech.com M.2 SATA Enclosure with USB-C | In Stock | £25.86 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £27.05 |
StarTech.com USB 3.1 / eSATA 1-bay Dock | In Stock | £54.05 |
StarTech.com Dual M.2 Enclosure - RAID | In Stock | £42.94 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £34.82 |
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 | In Stock | £29.33 |
StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 | In Stock | £38.05 |
StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA | In Stock | £49.25 |
