StarTech.com USB 3.0 Type-A to 5 Gigabit Ethernet Adapter - 5GBASE-T - 5G
Quicklinx: FK1SWS00 Mfr#: US5GA30
Add 5 GbE network access to your laptop, using the USB-A port on your laptop. This USB 3.0 Type-A to Gigabit network adapter gives you wired Ethernet network access.
Ideal for office or home use, the network adapter supports full 5 Gigabit bandwidth by harnessing the performance of USB 3.0. You can quickly access very large files over a 5 Gigabit network, saving valuable time every day.
Get up and running quickly. Simply plug this USB-A to Ethernet adapter into the USB port on your laptop and connect to your network. The Aquantia AQC111U chipset provides native driver support for Mac OS and Linux. Any Windows operating systems without the driver will be automatically prompted to download the software directly from the adapter, ensuring a quick installation with no Internet access required.
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port.
Startech 5GbE USB A to Ethernet Adapter - NBASE-T NIC - USB 3.0 Type A 2.5 GbE /5 GbE Multi Speed Gigabit Network USB 3.1 to RJ45/LAN - network adapter - USB-C 3.1 Gen 1 - 5GBase-T x 1 + USB 3.0
Network adapter
External
Interface (Bus) Type
USB-C 3.1 Gen 1
Ports
3.89 cm 2.4 cm
Cable Length
28.5 cm
81 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 5GBase-T, Ethernet 2.5GBase-BX
10Mb LAN, 100Mb LAN, 1GbE, 5GbE, 2.5GbE
Data Transfer Rate
5 Gbps
Jumbo frame size: 16000
Aquantia AQC111U
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3bz
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 7 / 8.1 / 10, Microsoft Windows Server 2019, Apple MacOS X 10.11 - 10.15, Linux Kernel 4.4 - 4.19 LTS versions
Network adapter
External
USB-C 3.1 Gen 1
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
5 Gbps
Status Indicators
Link/activity
Full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support, promiscuous mode
Processor / Memory
Aquantia AQC111U
1 x 5GBase-T - RJ-45 - receptacle , 1 x USB 3.0 - 9 pin USB Type A - plug
1 x USB 3.1 Gen 1 cable (integrated)
FCC, RoHS, WEEE, REACH
3.89 cm
2.4 cm
Cable Length
28.5 cm
81 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
108 g
70 °C
5 - 90% (non-condensing)
