StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port
Quicklinx: 8WSDWS00 Mfr#: USB32000SPT
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet, Gigabit Ethernet
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
£52.45 ex VAT
£62.94 inc VAT
Add two Gigabit Ethernet ports and a USB 3.0 pass-through port to your laptop through a single USB 3.0 port. The USB32000SPT USB 3.0 to Dual Port Gigabit Ethernet Adapter lets you add two Gigabit Ethernet ports to your laptop or Ultrabook computer through a single USB 3.0 port, and features an integrated USB 3.0 pass-through port that keeps your USB port available for use with external storage or other peripherals. Each RJ45 port supports 10/100/1000 Mbps Ethernet and is fully compatible with IEEE 802.3i/u/ab standards.
This 2-port USB LAN adapter is a versatile solution for connecting to two separate physical networks simultaneously, leveraging the 5 Gbps speed of USB 3.0 to provide dedicated gigabit bandwidth to each port. The dual USB NIC is also ideal for providing dedicated physical network interfaces to virtual machine configurations. Great for IT administrators that require dual-homed or multi-homed host systems.
The USB 3.0 NIC supports IPv4/IPv6 packet Checksum Offload Engine (COE) and TCP large send offload to reduce the load on your CPU, as well as Jumbo Frames, full-duplex operation with 802.3x flow control, and VLAN tagging for an efficient and full-featured USB network adapter.
  • Reliable performance
    Equipped to handle high-speed data needs, this adapter supports data link protocols including Ethernet, Fast Ethernet, and Gigabit Ethernet, ensuring smooth connections.
  • User-friendly setup
    The integrated USB connectivity allows for simple Plug-and-Play installation without the need for additional drivers, making it easy to expand network capabilities.
  • Flexible connectivity options
    With two Ethernet ports, this adapter allows multiple connections simultaneously, providing flexibility for devices that require wired networking.
  • Environmentally compliant
    Complies with FCC and RoHS standards, ensuring that the materials used are safe and non-toxic, contributing to an environmentally friendly product.
StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter w/ USB Port - 10/100/100 - USB Gigabit LAN Network NIC Adapter (USB32000SPT) - network adapter - USB 3.0 - 2 ports
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
6.1 cm x 7.5 cm x 1.5 cm
50 g
Ports Qty
2 ports
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
Network adapter - 2 ports
External
SuperSpeed USB 3.0
Wired
Cabling Type
Status Indicators
Port transmission speed, link/activity
Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, VLAN Tagging (not supported in MacOS)
2 x 1000Base-T - RJ-45 , 1 x USB 3.0 - 9 pin USB Type A
1 x SuperSpeed USB 3.0 - 9 pin USB Type A
1 x USB cable (integrated) - 20.32 m
FCC, RoHS
Software Included
Drivers & Utilities
6.1 cm
7.5 cm
1.5 cm
50 g
50 °C
5 - 85%
8WSD StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter In Stock £23.78
8WSD StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £38.92
8WSD StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White In Stock £21.64
8WSD StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port In Stock £52.45
8WSD StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black In Stock £30.45
8WSD StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White In Stock £28.24
8WSD StarTech.com USB 3.0 Network Adapter-Silver In Stock £25.45
8WSD StarTech.com USB to Ethernet Adapter - 1Gb In Stock £20.84
Protocol: Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
