StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White
Quicklinx: 8KRHWS00 Mfr#: ST3300U3S
Hurry, only 2 left in stock!
£38.00 ex VAT
£45.60 inc VAT
Add Gigabit Ethernet connectivity and 3 USB 3.0 Hub ports to a computer through a single SuperSpeed USB 3.0 port. The ST3300U3S USB 3.0 Gigabit Network Adapter turns a single SuperSpeed USB 3.0 host connection port into an RJ45 Gigabit network port as well as three additional USB 3.0 hub ports.
Unlike a USB 2.0-based adapter, this USB 3.0-based NIC lets you connect to your home or office network at full Gigabit bandwidth, with support for 10/100/1000Mbps. Plus, with support for features such as Jumbo Frames, VLAN tagging and Wake on LAN (WoL), this versatile network adapter offers a comprehensive Gigabit network solution.
On top of Gigabit Ethernet connectivity, the adapter also adds three USB 3.0 hub ports to your system, which allow you to connect external storage or other USB peripherals locally to the host computer. The hub ports support USB 3.0 speeds of up to 5 Gbps, as well as fast charging for mobile devices (e.g. iPhone, iPad and most Android devices).
Backward compatible with USB 2.0 and USB 1.x standards, the Gigabit Adapter/USB 3.0 hub will still support older USB devices and can also be used with an older system that does not have USB 3.0 ports (network speed limited by USB 1.x/2.0 bus), allowing you to mix and match USB 3.0/2.0/1.x devices. For further portability, the adapters can be used with or without the included external power adapter, eliminating the hassle of having to find an available wall outlet.
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White - USB 3 Ethernet Adapter - USB Charging Hub (ST3300U3S) - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Jumbo Frame Support
WOL, auto-uplink (auto MDI/MDI-X), VLAN Tagging (not supported in MacOS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
AC 120/230 V
7.5 cm x 5.5 cm x 1.5 cm
75 g
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Jumbo Frame Support
Status Indicators
Power, link/activity
3 x USB 3.0 Type A , 1 x micro-USB 3.0 Type B , 1 x 1000Base-T RJ-45
External power adapter
AC 120/230 V
1 x USB cable
FCC, RoHS
Software Included
Drivers & Utilities
7.5 cm
5.5 cm
1.5 cm
75 g
50 °C
5 - 85%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
8KRH StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £21.26
8KRH StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £38.36
8KRH StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter In Stock £23.36
8KRH StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £38.00
8KRH StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White In Stock £20.71
8KRH StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps In Stock £20.19
8KRH StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port In Stock £52.06
8KRH StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black In Stock £29.53
8KRH StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White In Stock £27.51
8KRH StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £39.16
8KRH StarTech.com 3 Port PCIe USB 3.0 Card + GbE In Stock £42.00
8KRH StarTech.com USB 3.0 Network Adapter-Silver In Stock £23.74
8KRH StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
8KRH StarTech.com 3Pt Portable USB 3.0 Hub + GbE In Stock £34.00
8KRH StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £43.58
8KRH StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £25.84
8KRH StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 In Stock £46.96
8KRH StarTech.com USB to Ethernet Adapter - 1Gb In Stock £20.50
