Add 3 external USB 3.0 ports with UASP and a Gigabit Ethernet port to your Ultrabook or laptop through a single USB 3.0 port. The ST3300GU3B Portable USB 3.0 Hub features an integrated GbE port, enabling you to expand your laptop connectivity by adding three external USB 3.0 ports, as well as a Gigabit network port via a single USB 3.0 connection. This hub is an ideal laptop accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface Book, Dell XPS 13, and many other devices.
The hub merges Gigabit network support and USB 3.0 hub access into lightweight yet sturdy aluminum casing, providing vital connectivity ports that are often limited or nonexistent on modern mobile computers, while remaining compact and travel-friendly. Plus, with an attached USB 3.0 host connection cable there's no need to carry a separate cable with you, so you can tuck the hub neatly into your laptop bag for maximum portability.
For faster and more consistent network connections, the integrated Ethernet port leverages the 5 Gbps capabilities of the USB 3.0 interface to provide wired Gigabit access that is fully compatible with IEEE 802.3/u/ab standards.
An ideal laptop accessory, this mobile USB hub is great for connecting low-power peripherals like a mouse, keyboard or USB flash drive, and also includes a universal power adapter for connecting devices.
Robust connectivity options
This hub includes three USB 3.0 ports alongside an RJ-45 Ethernet connector, allowing for multiple devices to connect simultaneously and providing high-speed Internet access. -
Wide compatibility
Designed to work seamlessly with Windows, Mac, and Unix systems, making it suitable for a range of users and applications. -
Efficient data transfer
Supports data transfer speeds of up to 5 Gbps through its USB 3.0 connections, ensuring fast and reliable connections for data-intensive tasks. -
Environmentally compliant
Meets RoHS and FCC standards, reflecting a commitment to environmental responsibility and safety in design. -
Compact and portable design
Its desktop form factor makes it easy to integrate into any workspace without taking up unnecessary space.
- StarTech.com USB 3.0 Hub with Gigabit Ethernet Adapter - 3 Port - NIC - USB Network / LAN Adapter - Windows & Mac Compatible (ST3300GU3B) - hub - 3 ports
- Hub - 3 ports
- Subtype
- USB
- Ports
- 3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
- Auto-uplink (auto MDI/MDI-X), full duplex mode
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
- Power
- AC 120/230 V
- 4.3 cm x 8.7 cm x 1.4 cm
- 61 g
- Black
- System Requirements
- Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
- 2-year warranty
- Designed For
- P/N: PEXUSB3S2EI, PEXUSB3S42, PEXUSB3S7, SVA5H2NEUA
- Hub - 3 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Processor
- X ASIX AX88179
- Status Indicators
- Link/activity
- 3 x USB 3.0 Type A , 1 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 4.3 cm
- 8.7 cm
- 1.4 cm
- 61 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 85% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 75 °C
- Designed For
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £20.74 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.73 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White | In Stock | £37.08 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps | In Stock | £20.00 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £20.25 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black | In Stock | £29.25 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White | In Stock | £26.84 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power | In Stock | £22.94 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £78.58 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power | In Stock | £19.21 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £46.54 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £38.80 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £55.27 |
StarTech.com 3 Port PCIe USB 3.0 Card + GbE | In Stock | £40.98 |
StarTech.com 3Pt Portable USB 3.0 Hub + GbE | In Stock | £33.70 |
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop | In Stock | £42.51 |
StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White | In Stock | £25.61 |
StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 | In Stock | £45.82 |
StarTech.com DC Power Adapter - 5V, 2A | In Stock | £9.67 |
