Add a Gigabit Ethernet port and a USB 3.0 pass-through port to your laptop through a single USB 3.0 port. The USB31000SPTB USB 3.0 to Gigabit Ethernet Adapter lets you add a Gigabit network port to your laptop or Ultrabook computer through a USB 3.0 port, and features an integrated USB 3.0 pass-through port that keeps your USB port available for use with other peripherals. The RJ45 port supports 10/100/1000 Mbps Ethernet and is fully compatible with IEEE 802.3i/u/ab standards.
An ideal replacement LAN adapter or laptop accessory, this compact USB 3.0 NIC leverages the 5 Gbps speed of USB 3.0 to provide full gigabit bandwidth and also offers backward compatibility with USB 2.0 systems (speed limited by USB bus).
The adapter supports features such as IPv4/IPv6 packet Checksum Offload Engine (COE) and TCP large send offload to reduce the load on your CPU. Jumbo Frames, full-duplex operation with 802.3x flow control and VLAN tagging are also supported, making this an efficient and full-featured USB network adapter.
Enhanced connectivity
The USB 3.0 Ethernet Adapter connects devices to wired networks using a reliable RJ-45 connector, ensuring robust network access. -
Compact design
With an integrated form factor, the adapter is compact and easy to transport, ideal for various networking needs. -
Temperature resilient
Designed to operate in environments ranging from 0°C to 50°C, this adapter performs well in diverse temperature conditions. -
Multiple protocol support
Supports a range of Ethernet protocols including Gigabit Ethernet and Fast Ethernet, providing versatility for different networking demands. -
User-friendly features
Includes indicators for port transmission speed and link/activity, as well as features like full duplex capability and flow control.
- StarTech.com USB 3.0 Ethernet Adapter - USB 3.0 Network Adapter NIC with USB Port - USB to RJ45 - USB Passthrough (USB31000SPTB) - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- 3.5 cm x 8.2 cm x 1.7 cm
- 50 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Processor
- ASIX AX88179
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
- Black
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Google Chrome OS 55 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
- 2-year warranty
- Designed For
- P/N: TB33A1C
- Network adapter
- Form Factor
- External
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Status Indicators
- Port transmission speed, link/activity
- Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, VLAN Tagging (not supported in MacOS)
Processor / Memory
- Processor
- ASIX AX88179
- 1 x 1000Base-T - RJ-45 - female , 1 x USB 3.0 - 9 pin USB Type A - female
- Cables Included
- 1 x USB cable (integrated) - 15.24 cm
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 3.5 cm
- 8.2 cm
- 1.7 cm
- 50 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 85%
- Designed For
- P/N: TB33A1C
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White | In Stock | £38.00 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps | In Stock | £20.19 |
StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port | In Stock | £52.06 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black | In Stock | £29.53 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White | In Stock | £27.51 |
StarTech.com USB 2.0 to 10/100 Mbps Ethernet Network Adapter Dongle | In Stock | £13.83 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £39.78 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £57.25 |
