StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black
Quicklinx: 90WQWS00 Mfr#: usb31000sptb
Wired / Wireless: Wired
Protocol: Fast Ethernet, Gigabit Ethernet, Ethernet
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
30 In Stock
£29.25 ex VAT
£35.10 inc VAT
Add a Gigabit Ethernet port and a USB 3.0 pass-through port to your laptop through a single USB 3.0 port. The USB31000SPTB USB 3.0 to Gigabit Ethernet Adapter lets you add a Gigabit network port to your laptop or Ultrabook computer through a USB 3.0 port, and features an integrated USB 3.0 pass-through port that keeps your USB port available for use with other peripherals. The RJ45 port supports 10/100/1000 Mbps Ethernet and is fully compatible with IEEE 802.3i/u/ab standards.
An ideal replacement LAN adapter or laptop accessory, this compact USB 3.0 NIC leverages the 5 Gbps speed of USB 3.0 to provide full gigabit bandwidth and also offers backward compatibility with USB 2.0 systems (speed limited by USB bus).
The adapter supports features such as IPv4/IPv6 packet Checksum Offload Engine (COE) and TCP large send offload to reduce the load on your CPU. Jumbo Frames, full-duplex operation with 802.3x flow control and VLAN tagging are also supported, making this an efficient and full-featured USB network adapter.
  • Enhanced connectivity
    The USB 3.0 Ethernet Adapter connects devices to wired networks using a reliable RJ-45 connector, ensuring robust network access.
  • Compact design
    With an integrated form factor, the adapter is compact and easy to transport, ideal for various networking needs.
  • Temperature resilient
    Designed to operate in environments ranging from 0°C to 50°C, this adapter performs well in diverse temperature conditions.
  • Multiple protocol support
    Supports a range of Ethernet protocols including Gigabit Ethernet and Fast Ethernet, providing versatility for different networking demands.
  • User-friendly features
    Includes indicators for port transmission speed and link/activity, as well as features like full duplex capability and flow control.
StarTech.com USB 3.0 Ethernet Adapter - USB 3.0 Network Adapter NIC with USB Port - USB to RJ45 - USB Passthrough (USB31000SPTB) - network adapter - USB 3.0 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
3.5 cm x 8.2 cm x 1.7 cm
50 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
ASIX AX88179
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Google Chrome OS 55 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
P/N: TB33A1C
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Status Indicators
Port transmission speed, link/activity
Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, VLAN Tagging (not supported in MacOS)
Processor / Memory
ASIX AX88179
1 x 1000Base-T - RJ-45 - female , 1 x USB 3.0 - 9 pin USB Type A - female
1 x USB cable (integrated) - 15.24 cm
FCC, RoHS
Software Included
Drivers & Utilities
3.5 cm
8.2 cm
1.7 cm
50 g
50 °C
5 - 85%
P/N: TB33A1C
90WQ StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £37.08
90WQ StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps In Stock £20.00
90WQ StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port In Stock £50.79
90WQ StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black In Stock £29.25
90WQ StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White In Stock £26.84
90WQ StarTech.com USB 2.0 to 10/100 Mbps Ethernet Network Adapter Dongle In Stock £13.49
90WQ StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £38.80
90WQ StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £55.27
Protocol: Gigabit Ethernet
Protocol: Ethernet
Compatibility: Mac
Compatibility: PC
