StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White
Quicklinx: 91F3WS00 Mfr#: USB31000SPTW
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
Hurry, only 3 left in stock!
£27.51 ex VAT
£33.01 inc VAT
Add a Gigabit Ethernet port and a USB 3.0 pass-through port to your laptop through a single USB 3.0 port. The USB31000SPTW USB 3.0 to Gigabit Ethernet Adapter lets you add a Gigabit network port to your Macbook or Ultrabook computer through a USB 3.0 port, and features an integrated USB 3.0 pass-through port that keeps your USB port available for use with other peripherals. The RJ45 port supports 10/100/1000 Mbps Ethernet and is fully compatible with IEEE 802.3i/u/ab standards.
An ideal replacement LAN adapter or laptop accessory, this compact USB 3.0 NIC leverages the 5 Gbps speed of USB 3.0 to provide full gigabit bandwidth and also offers backward compatibility with USB 2.0 systems (speed limited by USB bus).
The adapter supports features such as IPv4/IPv6 packet Checksum Offload Engine (COE) and TCP large send offload to reduce the load on your CPU. Jumbo Frames, full-duplex operation with 802.3x flow control and VLAN tagging are also supported, making this an efficient and full-featured USB network adapter.
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port (White) - USB 3.0 NIC - 10/100/1000 Mbps USB 3.0 LAN Adapter (USB31000SPTW) - network adapter - USB 3.0 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
3.5 cm x 8.2 cm x 1.7 cm
50 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
ASIX AX88179
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
White
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Status Indicators
Port transmission speed, link/activity
Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, VLAN Tagging (not supported in MacOS)
Processor / Memory
ASIX AX88179
1 x 1000Base-T - RJ-45 - female , 1 x USB 3.0 - 9 pin USB Type A - female
1 x USB cable (integrated) - 15.24 cm
FCC, RoHS
White
Software Included
Drivers & Utilities
3.5 cm
8.2 cm
1.7 cm
50 g
50 °C
5 - 85%
91F3 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £38.00
91F3 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps In Stock £20.19
91F3 StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port In Stock £54.46
91F3 StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black In Stock £29.53
91F3 StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White In Stock £27.51
91F3 StarTech.com USB 2.0 to 10/100 Mbps Ethernet Network Adapter Dongle In Stock £13.59
91F3 StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £39.78
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
