StarTech.com USB 3.0 to 2.5/3.5" SATA HDD / SSD Duplicator Dock - Standalone Hard Drive / HDD Clone
Quicklinx: 93K4WS00 Mfr#: SATDOCK2REU3
£67.83 ex VAT
£81.39 inc VAT
Clone a 2.5in/3.5in SATA drive without a host computer connection, or dock the drives over USB 3.0 for easy access. The SATDOCK2REU3 USB 3.0 Standalone Duplicator and Eraser Dock lets you connect your 2.5in/3.5in SATA HDDs or SSDs through SuperSpeed USB 3.0, with the ability to swap drives in and out as needed. The dock also functions as a standalone drive duplicator and eraser - an efficient and versatile solution for external drive management.
Featuring standalone Sector by Sector hard drive duplication with built-in LED progress bar, and support for 2 drive single pass over writing the SATDOCK22EU3 is a user-friendly all-in-one solution for any application requiring hard drive duplication or erasing.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD/SSD docking station is compatible with virtually any SATA hard drive, and greatly increases the storage/backup capabilities of your computer.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in IDE hard drive into a SATA hard drive dock.
StarTech.com Dual Bay Hard Drive Duplicator and Eraser, Standalone HDDSSD ClonerCopier, USB 3.0 to SATA Docking Station, Hard Disk Duplicator and Sanitizer Dock - ToollessTop-Loading Design - hard drive duplicator
Hard drive duplicator
0 (installed) / 2 (max)
Supported Drives
SATA-300
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
No HDD
Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
AC 120/230 V
10.3 cm x 12.8 cm x 6.2 cm
424 g
P/N: SVA12M5NA
Chassis
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-300
Storage Controller
SATA - integrated (USB 3.0)
Interface Type
SATA 3Gb/s
Max Storage Devices Qty
2
Hard Drive
No HDD
Expansion Bays
External - 2.5" , External - 3.5"
1 x USB 3.0 - 9 pin USB Type B , 2 x SATA 3Gb/s - 22 pin Serial ATA
Tested with up to 4TB 7200 RPM 3.5" hard drives, tested with up to 1TB 7200 RPM 2.5" hard drives
1 x USB cable
FCC, RoHS
External power adapter
AC 120/230 V
10.3 cm
12.8 cm
6.2 cm
424 g
85 °C
5 - 90%
P/N: SVA12M5NA
93K4 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.30
93K4 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £28.32
93K4 StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.99
93K4 StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £409.75
93K4 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.52
93K4 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £35.47
93K4 StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser In Stock £118.08
93K4 StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed In Stock £287.21
93K4 StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser In Stock £441.84
93K4 StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps In Stock £84.05
93K4 StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library In Stock £268.30
93K4 StarTech.com USB 3.0 Standalone Eraser Dock In Stock £209.69
93K4 StarTech.com Hard Disk Drive Duplicator Dock In Stock £80.83
93K4 StarTech.com SATA/SAS Duplicator & Eraser In Stock £1,045.83
93K4 StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
93K4 StarTech.com USB and SATA Cloner / Eraser In Stock £485.61
93K4 StarTech.com StarTech.com Hard Drive Eraser In Stock £499.61
93K4 StarTech.com USB Duplicator and Eraser 1:15 In Stock £1,045.73
93K4 StarTech.com USB Duplicator and Eraser 1:7 In Stock £661.43
93K4 StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £691.38
Type: Hard drive Duplicator
HD Size: 2.5 / 3.5 shared
Power Supply: Power adapter
