StarTech.com USB 3.0 Standalone Eraser Dock
Quicklinx: BJX2WS00 Mfr#: SDOCK1EU3P
Type: Hard Drive Eraser
HD Size: 2.5 / 3.5 shared
Power Supply: [N/A]
£210.95 ex VAT
£253.14 inc VAT
Securely erase a SATA HDD/SSD without a host device, or dock your drive for easy access. Make the most of your SATA drives. This standalone eraser dock lets you erase your 2.5" and 3.5" solid-state drives or hard drives without connecting to a host computer, making it easy to re-use or re-purpose your SATA drive. For added peace of mind, the dock offers a printed confirmation when data has been securely erased.
The eraser dock also gives you a single-bay dock for your SATA drive with fast USB 3.0 performance, also known as USB 3.1 Gen 1 (5 Gbps). Using industry-recognized erase modes, you can rest assured that the standalone eraser securely cleans, erases or sanitizes the data from your 2.5" or 3.5" SSD or HDD.
The eraser dock supports nine erase modes including: Quick Erase, Single and Multi-pass Overwrites, Custom Erase, Secure Erase and Enhanced Secure Erase. The Multi-pass Overwrite (3-Pass Full Disk Overwrite) erase procedures meet the requirements of DoD (5220.22-M) standards.
The eraser dock lets you connect to a serial printer to print a record of the erase procedure, and confirm that the erase has been successfully completed. This feature is ideal for IT technicians, system administrators or any departments needing confirmation when erasing sensitive or confidential information. For your reference, the printed receipt clearly shows you the time and date of erase, as well as the erase mode used.
For IT technicians or business professionals who need to check files or test different hard drives, the dock lets you hot-swap drives in and out as needed. The dock features a single SATA bay with a top-loading design for easy drive access, which makes it easy to quickly back-up or transfer data to a hard drive or solid-state drive.
With support for SATA I and II and large capacity drives (tested up to 6TB), this docking station is compatible with virtually any 2.5" and 3.5" SATA SSD or HDD drive.
The eraser dock also works with 2.5" and 3.5" IDE hard drives, mSATA drives and M.2 drives using a compatible StarTech.com adapter.
The eraser dock is OS independent which ensures a quick and easy setup. Its compact design and small footprint allows it to tuck easily into your workspace.
  • Industry-recognized erase modes
    Using industry-recognized erase modes, you can rest assured that the standalone eraser securely cleans, erases or sanitizes the data from your 2.5" or 3.5" SSD or HDD.The eraser dock supports nine erase modes including: Quick Erase, Single and Multi-pass Overwrites, Custom Erase, Secure Erase and Enhanced Secure Erase. The Multi-pass Overwrite (3-Pass Full Disk Overwrite) erase procedures meet the requirements of DoD (5220.22-M) standards.
  • Wipe sensitive data securely, confirmed with a printed receipt
  • Easy drive management and wide compatibility
    For IT technicians or business professionals who need to check files or test different hard drives, the dock lets you hot-swap drives in and out as needed. The dock features a single SATA bay with a top-loading design for easy drive access, which makes it easy to quickly back-up or transfer data to a hard drive or solid-state drive. With support for SATA I and II and large capacity drives (tested up to 6TB), this docking station is compatible with virtually any 2.5" and 3.5" SATA SSD or HDD drive.
  • Hassle-free set-up and a compact design
StarTech.com USB 3.0 Hard Drive Eraser Dock for 2.5" & 3.5" SATA/ IDE SSD HDD + mSATA & M.2 - Standalone Secure Erase Wiper & Sanitizer (SDOCK1EU3P) - hard drive eraser
Hard drive eraser
Package Content
USB cable, external power adapter
Product Material
Plastic
12.3 cm x 14 cm x 7 cm
570 g
P/N: SVA12M5NA
Hard drive eraser
Product Material
Plastic
Package Content
12.3 cm
14 cm
7 cm
570 g
LCD display, LED indicator, tested with up to 6TB 7200 RPM hard drives
FCC, RoHS
P/N: SVA12M5NA
BJX2 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
BJX2 StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
BJX2 StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £416.04
BJX2 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £14.55
BJX2 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
BJX2 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
BJX2 StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps In Stock £70.30
BJX2 StarTech.com USB 3.0 Standalone Eraser Dock In Stock £210.95
BJX2 StarTech.com Hard Disk Drive Duplicator Dock In Stock £80.20
BJX2 StarTech.com SATA/SAS Duplicator & Eraser In Stock £998.03
BJX2 StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
BJX2 StarTech.com USB and SATA Cloner / Eraser In Stock £472.21
BJX2 StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn In Stock £238.79
BJX2 StarTech.com StarTech.com Hard Drive Eraser In Stock £491.94
BJX2 StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £751.08
Power Supply: [N/A]
