StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock –  Hard Drive Cloner 6Gbps
Quicklinx: 9M7BWS00 Mfr#: SDOCK2U33RE
Type: Storage controller
HD Size: 3.5, 2.5
Power Supply: [N/A]
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Hurry, only 3 left in stock!
£70.30 ex VAT
£84.36 inc VAT
Clone a 2.5in/3.5in SATA drive without a host computer connection, or dock the drives over USB 3.0 or eSATA for easy access. The SDOCK2U33RE Dual 2.5/3.5" SATA HDD/SSD duplicator dock lets you duplicate/clone an existing hard drive without the use of a host computer system - or dock and swap drives from your desktop or laptop computer simultaneously, using a single USB or eSATA port.
The SDOCK2U33RE offers convenient dual-function performance. As a hard drive duplicator, the SDOCK2U33RE lets you create an exact sector-by-sector clone from one hard drive to another, including partitions and boot sector information - ensuring data integrity and consistency for sensitive operations, such as data recovery. As an external hard drive dock the SDOCK2U33RE lets you connect your drives through either eSATA or USB, with each drive slot individually supporting high capacity 2.5/3.5" hard drives or solid state drives, tested up to 4 TB.
With support for SATA III (6 Gbps) you can maximize efficiency with duplication speeds up to 22 GB per minute, and eSATA docking speeds up to 6 Gbps. The Dock can also be connected through USB 3.0 with UASP for transfer speeds up 5 Gbps (70% faster than conventional USB 3.0).
With push button operation and plug-and play installation, the duplicator dock has been specially designed for hassle-free operation. The SDOCK2U33RE lets you quickly dock your hard drives or start duplicating hard drives with the push of a button. Plus, the built-in LED progress bar saves you time by letting you easily monitor the entire duplication process, so you'll know exactly when it's time to start your next operation.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in. IDE hard drive into a SATA hard drive dock.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
  • Versatile Features
  • Fast Performance
    With support for SATA III (6 Gbps) you can maximize efficiency with duplication speeds up to 22 GB per minute, and eSATA docking speeds up to 6 Gbps. The Dock can also be connected through USB 3.0 with UASP for transfer speeds up 5 Gbps (70% faster than conventional USB 3.0). See our UASP testing results below for further details.
  • Hassle-free Operation
    With push button operation and plug-and play installation, the duplicator dock has been specially designed for hassle-free operation. The SDOCK2U33RE lets you quickly dock your hard drives or start duplicating hard drives with the push of a button. Plus, the built-in LED progress bar saves you time by letting you easily monitor the entire duplication process, so you'll know exactly when it's time to start your next operation. For added compatibility with different drive types in duplication and docking applications, the SDOCK2U33RE supports the use of various drive adapters. The below list of StarTech.com adapters have been specifically tested, to ensure compatibility with this drive duplicator: 2.5/3.5in IDE drives - SAT2IDEADP mSATA drives - SAT2MSAT25 M.2 (NGFF) drives - SAT32M225 SDOCK2U33RE is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Improved Performance with UASP
    UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance. At the same peak in testing UASP also shows an 80% reduction in required processor resources. Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com Dual Bay Hard Drive Duplicator, Standalone USB 3.0 (5 Gbps) eSATA to 2.53.5 SATA III HDDSSD ClonerCopier, Hard Drive Docking Station - Hard Disk Cloner - storage controller - SATA 6Gb/s - USB 3.0
Storage controller - external
Bus Type
USB 3.0
Expansion Bays
2 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
Power indicator
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
AC 120/230 V
Linux, Microsoft Windows 2000, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
13.2 cm x 14.8 cm x 7 cm
1 kg
P/N: SVA12M5NA
2.5", 3.5"
Host Bus
USB 3.0
Power indicator
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Bays
1 x SATA 6Gb/s - eSATA , 2 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B
Tested with up to 4TB 7200 RPM 3.5" hard drives, tested with up to 2TB 5900 RPM 2.5" hard drives
Plug and Play, FCC, RoHS
Power adapter
AC 120/230 V
13.2 cm
14.8 cm
7 cm
1 kg
5 °C
35 °C
20 - 80%
P/N: SVA12M5NA
9M7B StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
9M7B StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £43.38
9M7B StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
9M7B StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
9M7B StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £416.04
9M7B StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.36
9M7B StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
9M7B StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD In Stock £63.79
9M7B StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps In Stock £70.30
9M7B StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library In Stock £268.90
9M7B StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £56.24
9M7B StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £82.78
9M7B StarTech.com USB 3.0 Standalone Eraser Dock In Stock £210.95
9M7B StarTech.com Hard Disk Drive Duplicator Dock In Stock £80.20
9M7B StarTech.com SATA/SAS Duplicator & Eraser In Stock £998.03
9M7B StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £54.05
9M7B StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
9M7B StarTech.com USB and SATA Cloner / Eraser In Stock £472.21
9M7B StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn In Stock £238.79
9M7B StarTech.com StarTech.com Hard Drive Eraser In Stock £491.94
9M7B StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £751.08
HD Size: 3.5
HD Size: 2.5
Power Supply: [N/A]
