StarTech.com Hard Disk Drive Duplicator Dock
Quicklinx: C5SMWS00 Mfr#: SDOCK2U313R
13 In Stock
£78.24 ex VAT
£93.88 inc VAT
Duplicate or dock a SATA SSD/HDD with fast performance - works with both USB-C and USB-A enabled devices. Duplicate drives quickly, at rates of up to 28GB per minute for SSDs, without having to connect to your computer. This duplicator dock offers standalone drive cloning that makes it easy to back up your data and make exact images of your drives. You can also connect the dock to your computer through USB 3.1 (10Gbps), to dock and swap your drives as part of a scalable storage solution.
Duplicating a hard drive or solid-state drive is an effective way to migrate your operating system and data from one drive to another, or create an exact copy for safeguarding your important data. This drive duplicator lets you create a sector-by-sector clone of your drive, including partitions and boot sector information, to ensure data integrity and consistency for sensitive operations such as data recovery.
The duplicator dock saves you valuable time with SSD duplication speeds of up to 28GB per minute. You can duplicate a 2.5" or 3.5" SATA SSD or HDD easily, without having to connect the duplicator to a host computer.
The duplicator dock also provides an external storage solution, letting you dock your drives through USB 3.1 Gen 2 with UASP support, enabling fast data transfer rates of up to 10Gbps. Each drive slot individually supports a high-capacity hard drive or solid-state drive, tested up to 6 TB.
The duplicator dock comes with two USB cables for flexible use with the latest laptops and tablets equipped with a USB-C port, as well as legacy devices. It includes both USB-C to B and USB-A to B cables. The duplicator dock is also compatible with a Thunderbolt 3 USB-C port.
The dock features a top-loading, toaster-style design that makes it easy to insert your drives. It also features drive doors to help stabilize drives that are inserted into the slot and prevent foreign objects from getting into the drive slots.
Both tool-less and tray-less, the duplicator dock helps to ensure quick and hassle-free drive insertions. LED indicators let you know, at a glance, the current state of the duplication process, including the specific duplication mode, the HDD status and clone progress. The HDD ejection button enables fast and simple drive removal.
For added compatibility with different drive types in duplication and docking applications, the SDOCK2U33RE supports the use of various drive adapters. The below list of StarTech.com adapters have been specifically tested, to ensure compatibility with this drive duplicator: SATA to 2.5in or 3.5in IDE Drive Adapter - SAT2IDEADP; 2.5in SATA to Mini SATA SSD Adapter - SAT2MSAT25; M.2 SSD to 2.5in SATA Adapter - SAT32M225.
  • Includes two USB cables for versatility
  • Designed for easy use
    The dock features a top-loading, toaster-style design that makes it easy to insert your drives. It also features drive doors to help stabilize drives that are inserted into the slot and prevent foreign objects from getting into the drive slots. Both tool-less and tray-less, the duplicator dock helps to ensure quick and hassle-free drive insertions. LED indicators let you know, at a glance, the current state of the duplication process, including the specific duplication mode, the HDD status and clone progress. The HDD ejection button enables fast and simple drive removal. For added compatibility with different drive types in duplication and docking applications, the SDOCK2U33RE supports the use of various drive adapters. The below list of StarTech.com adapters have been specifically tested, to ensure compatibility with this drive duplicator: SATA to 2.5in or 3.5in IDE Drive Adapter - SAT2IDEADP 2.5in SATA to Mini SATA SSD Adapter - SAT2MSAT25 M.2 SSD to 2.5in SATA Adapter - SAT32M225 The SDOCK2U313R is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Standalone Hard Drive Duplicator, Dual Bay HDDSSD ClonerCopier, USB 3.1 (10 Gbps) to SATA III (6Gbps) HDDSSD Docking Station, Hard Disk Duplicator Dock - Hard Drive Cloner - hard drive duplicator
Hard drive duplicator
0 (installed) / 2 (max)
Supported Drives
SATA-300
Duplication Speed
28 GBpm
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
No HDD
13.2 cm x 14.2 cm x 7 cm
508 g
P/N: TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
Duplication Speed
28 GBpm
Chassis
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-300
Storage Controller
SATA (USB 3.1)
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Max Storage Devices Qty
2
Hard Drive
No HDD
Expansion Bays
2 (total) / 2 (free) x internal - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B
LED indicator, UASP transfer protocol
2 x USB cable
External power adapter
13.2 cm
14.2 cm
7 cm
508 g
C5SM StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.30
C5SM StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.08
C5SM StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.16
C5SM StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £405.90
C5SM StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.07
C5SM StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.16
C5SM StarTech.com 1m USB 3 Cable Right Angle BK In Stock £6.83
C5SM StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.73
C5SM StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps In Stock £68.59
C5SM StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library In Stock £262.35
C5SM StarTech.com USB 3.0 / eSATA 6-Bay Hard Drive Duplicator Dock - 1:5 HDD / SSD Cloner and Eraser In Stock £899.11
C5SM StarTech.com USB 3.0 Standalone Eraser Dock In Stock £205.80
C5SM StarTech.com Hard Disk Drive Duplicator Dock In Stock £78.24
C5SM StarTech.com Dual-Bay SATA HDD/SSD Dock In Stock £50.40
C5SM StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £15.27
C5SM StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £692.85
Type: Hard drive Duplicator
HD Size: 2.5 / 3.5 shared
Power Supply: Power adapter
