StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M
Quicklinx: 8WSGWS00 Mfr#: USB3CAB1M
Select:
Hurry, only 3 left in stock!
£7.61 ex VAT
£9.13 inc VAT
Connect your USB 3.0 devices with this high-quality USB 3.0 certified cable. The USB3CAB1M 1-meter USB 3.0 A-to-B cable provides a high quality connection between peripheral devices that feature a USB 3.0 type-B port, such as hard drive enclosures, card readers, docking stations and video capture devices and a USB-capable computer.
This cable is USB-IF certified to USB 3.0 specifications, guaranteeing a dependable, long-lasting connection to your USB ''B'' devices.
  • Reliable connection
    This USB 3.0 cable features nickel-plated connectors that provide a secure and stable connection, enhancing overall performance and lifespan.
  • Fast data transfer
    With a data transfer rate of 5 Gbps, this cable allows users to move large files quickly and efficiently between devices.
  • Durable design
    The molded construction of the cable includes a strain relief feature, ensuring that it withstands everyday wear and tear while maintaining performance.
  • Versatile compatibility
    Designed with a 9-pin USB Type-B and USB Type-A male connectors, this cable is compatible with a wide range of devices including printers, external drives, and more.
  • Environmentally conscious
    This cable complies with RoHS and USB-IF standards, making it a responsible choice for environmentally aware consumers.
StarTech.com 1m 3 ft Certified SuperSpeed USB 3.0 A to B Cable Cord - USB 3 Cable - 1x USB 3.0 A (M), 1x USB 3.0 B (M) - 1 meter, Black (USB3CAB1M) - USB cable - USB Type B to USB Type A - 1 m
USB cable
Double shielded
Molded, strain relief, 5 Gbps data rate
Length
1 m
Connector
9 pin USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: HB30A4AIB, HB30AM4AB, HB30C4AIB, HB31C2A2CME, HB31C3A1CME, HB31C4AB, HBS304A24A, KITBXDOCKPNA, KITBXDOCKPUK, S351BMU33ET, S351BMU33ETG, S351BU313, S3520BU33ER, S352BU313R, S352BU33HR, SDOCK2U313R, SDOCKU313, SDOCKU313E, SDOCKU33EF, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
USB cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
1 m
Connector
USB 3.0, RoHS, USB-IF
P/N: HB30A4AIB, HB30AM4AB, HB30C4AIB, HB31C2A2CME, HB31C3A1CME, HB31C4AB, HBS304A24A, KITBXDOCKPNA, KITBXDOCKPUK, S3510BMU33, S3510SMU33, S351BMU33ET, S351BMU33ETG, S351BU313, S3520BU33ER, S352BU313R, S352BU33HR, SDOCK2U313R, SDOCKU313, SDOCKU313E, SDOCKU33EF, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
