StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M
Quicklinx: 8VTWWS00 Mfr#: USB3CAB2M
Length: 2m
Select:
20 In Stock
£9.63 ex VAT
£11.55 inc VAT
Connect your USB 3.0 devices, with this high-quality USB 3.0 certified cable. The USB3CAB2M 2-meter USB 3.0 A-to-B cable provides a high quality connection between peripheral devices that feature a USB 3.0 type-B port, such as hard drive enclosures, card readers, docking stations and video capture devices and a USB-capable computer.
This cable is USB-IF certified to USB 3.0 specifications, guaranteeing a dependable, long-lasting connection to your USB ''B'' devices.
  • Efficient data transfer
    This cable supports a data rate of 5 Gbps, allowing for quick and efficient file transfers between devices.
  • Shielded construction
    The shielded design helps reduce interference, ensuring reliable performance during data transfer.
  • Durable molded connectors
    Molded connectors enhance the durability of this cable, making it suitable for everyday use.
  • Corrosion-resistant connectors
    Nickel-plated connectors provide improved conductivity and resistance to corrosion, ensuring a longer lifespan.
  • Compliance with standards
    This cable is compliant with USB 3.0 and RoHS standards, ensuring quality and environmental responsibility.
StarTech 2m 6 ft Certified SuperSpeed USB 3.0 A to B Cable Cord - USB 3 Cable - 1x USB 3.0 A (M), 1x USB 3.0 B (M) - 2 meter, Black (USB3CAB2M) - USB cable - USB Type B to USB Type A - 2 m
USB cable
Shielded
Molded, 5 Gbps data rate
Cable Length
2 m
Connector
9 pin USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: HBS304A24A, KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, S3510BMU33, S3510SMU33, S351BMU33ET, S351BMU33ETG, S3520BU33ER, S352BU33HR, SDOCKU33EF, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
USB cable
Shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Cable Length
2 m
Connector
USB 3.0, RoHS
8VTW StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £9.63
8VTW StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.61
8VTW StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.41
Length: 2m
