StarTech.com Dual-Bay SATA HDD/SSD Dock
Quicklinx: D4FFWS00 Mfr#: SDOCK2U33V
Type: HDD docking station
HD Size: 2.5, 3.5
Power Supply: Power adapter
28 In Stock
£51.66 ex VAT
£61.99 inc VAT
Use this SATA hard drive docking station to gain quick access to two of your 2.5" or 3.5" SATA III SSDs/HDDs. This dual-bay SATA HDD/SSD docking station lets you dock and swap drives from your desktop or laptop computer simultaneously, using a single USB port. It supports two 2.5/3.5" SATA hard drives or solid-state drives.
The dual-bay docking station supports USB 3.0, also known as USB 3.1 Gen 1, providing fast data transfer speeds of up to 5Gbps. It also supports UASP, for enhanced performance.
Ideal for IT professionals, such as system administrators and technicians, the hard drive dock enables you to complete device-management tasks more efficiently, such as disk image duplication, data recovery, backing up and archiving hard drives, and transferring content between drives and devices. It also enhances your workflow, by providing quick access to your hard drives, with the ability to easily swap drives in and out as needed.
Designed for easy drive access, the hard drive dock enhances your workflow, by providing quick access to two hard drives, with the ability to easily swap drives in and out as needed. The hard drive dock features a convenient top-loading design with independent drive doors that make it easy to add or remove drives.
The dual-bay SATA HDD/SSD docking station is OS independent, with no drivers or software installation required, for easy setup.
  • Efficient hot-swap functionality
    The docking station features dual hot-swap bays that let users easily swap out drives without system downtime, enhancing workflow efficiency.
  • Fast data transfer rates
    With USB 3.0 connectivity, this docking station supports data transfer rates of up to 6 Gb/s, making file transfers quick and efficient.
  • Broad hard drive compatibility
    Compatible with both 2.5-inch and 3.5-inch SATA HDDs and SSDs, this docking station offers versatile support for a range of storage needs.
  • Robust construction
    Constructed from sturdy plastic and aluminum materials, the docking station ensures durability while maintaining a lightweight profile.
  • Reliable operational standards
    This product adheres to Plug-and-Play standards as well as FCC, RoHS, and WEEE compliances, ensuring user-friendly and sustainable design.
StarTech.com Dual-Bay USB 3.0 to SATA Hard Drive Docking Station, USB Hard Drive Dock, External 2.53.5 SATA IIIIII, SSDHDD Docking Station, Hot-Swap Hard Drive Bays - Top-Loading - HDD docking station - SATA 6Gb/s - USB 3.0
HDD docking station - external
Bays
2
Bus Type
USB 3.0
Expansion Bays
2 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Product Material
Plastic, aluminium
Power Source
Included AC adapter
AC 100 - 240 V
13 cm x 11.4 cm x 6.2 cm
730 g
P/N: SVA12M5NA
Bays
2
2.5", 3.5"
Host Bus
USB 3.0
Product Material
Plastic, aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
ASMedia ASM1153E
Bays
2 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B
1 x USB 3.0 cable - external
UASP transfer protocol, S.M.A.R.T. support, TRIM support, tested with up to 10TB 7200 RPM hard drives
Plug and Play, FCC, RoHS, WEEE
Power Source
Included AC adapter
Power adapter
AC 100 - 240 V
36 Watt
13 cm
11.4 cm
6.2 cm
730 g
5 °C
35 °C
20 - 80%
P/N: SVA12M5NA
D4FF StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
D4FF StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
D4FF StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.36
D4FF StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
D4FF StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
HD Size: 2.5
HD Size: 3.5
