StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP
Quicklinx: 95QRWS00 Mfr#: SDOCKU33BV
Type: Storage controller
HD Size: 3.5, 2.5
Power Supply: Power adapter
  • Windows 8 (32/64 bits)
Hurry, only 3 left in stock!
£38.06 ex VAT
£45.67 inc VAT
Dock your 2.5in or 3.5in SATA III SSDs/HDDs over USB 3.0 with UASP. The SDOCKU33BV UASP-enabled USB 3.0 docking station makes it easy for you to connect and swap 2.5in or 3.5in SATA III hard drives (HDD) and solid state drives (SSD) through an available USB port. The dock performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
With support for large capacity SATA I/II/III drives (tested up to 4TB), and 2.5in or 3.5in drives this HDD/SSD docking station is compatible with virtually any SATA drive, and greatly increases the storage/backup capabilities of your computer.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in IDE hard drive into a SATA hard drive dock.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0 SATA III Docking Station SSD / HDD with UASP - External Hot-Swap Dock w/ support for 2.5"/3.5" drives (SDOCKU33BV) - storage controller - SATA 6Gb/s - USB 3.0
Storage controller - external
Bus Type
USB 3.0
Hard Drive Form Factor Compatibility
2.5", 3.5"
Power indicator
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
AC 100/230 V
Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits)
P/N: SVA12M2NEUA, SVA12M5NA, USBDUP15, USBDUPE115, USBDUPE17
2.5", 3.5"
Host Bus
USB 3.0
Power indicator
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B
1 x USB cable - external
WHQL, FCC, RoHS
Power adapter
AC 100/230 V
5 °C
35 °C
20 - 80%
95QR StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
95QR StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
95QR StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.36
95QR StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
95QR StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP In Stock £38.06
95QR StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD In Stock £63.79
95QR StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.68
95QR StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £82.78
95QR StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £54.05
95QR StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
95QR StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
95QR StarTech.com Dual-Bay SATA HDD/SSD Dock In Stock £51.66
HD Size: 3.5
HD Size: 2.5
