Dock two of your 2.5" and 3.5" SATA drives over high performance USB 3.1 Gen 2 with UASP. Get unprecedented performance and storage capacity with this USB 3.1 Gen 2 (10 Gbps) dual-drive docking station. It supports both 2.5" and 3.5" form factor solid-state and hard drives, with a high capacity storage capability of 12TB (6TB per drive).
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
It's never been easier to dock and swap drives from your desktop computer or laptop. Simply insert your drives into the top loading slot, with no tools or trays required. The HDD ejection button allows fast and simple drive removal.
The dual-drive docking station comes with a USB Type-A to B cable, providing backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. It also supports UASP for enhanced performance.
Extend the value of this hard drive docking station further with the addition of the SAT2IDEADP" text="SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5" or 3.5" IDE hard drive into a SATA hard drive dock.
Convenient compatibility
The dual-drive docking station comes with a USB Type-A to B cable, providing backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. It also supports UASP for enhanced performance. Extend the value of this hard drive docking station further with the addition of our SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5" or 3.5" IDE hard drive into a SATA hard drive dock. The SDOCK2U313 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Dual-Bay USB 3.1 to SATA Hard Drive Docking Station, USB 3.1 (10 Gbps) Hard Drive Dock, External 2.53.5 SATA IIIIII, SSDHDD Docking Station, Hot-Swap Hard Drive Bay - Top-Loading - storage controller - USB 3.1 (Gen 2)
- Storage controller - external
- Bus Type
- USB 3.1 (Gen 2)
- Black
- Expansion Bays
- 2 x hot-swap - 2.5" / 3.5" shared
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Data indicator, power indicator
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Plastic
- Power
- AC 120/230 V
- 14.8 cm x 13.2 cm x 7 cm
- 530 g
- 2-year warranty
- 2.5", 3.5"
- Host Bus
- USB 3.1 (Gen 2)
- Product Material
- Plastic
- Black
Storage Controller
- Supported Devices
- Processor
- ASMedia ASM1352R
- Bays
- 2 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
- Cables Included
- 1 x USB cable - external , 4 x power connector adaptor - external
- LED indicator, tested with up to 6TB 7200 RPM hard drives, UASP transfer protocol
- FCC, RoHS
- Power adapter
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
- 14.8 cm
- 13.2 cm
- 7 cm
- 530 g
- 5 °C
- 35 °C
- 20 - 80%
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £29.35 |
StarTech.com USB 3.1 Gen 2 Single-bay Dock | In Stock | £53.60 |
StarTech.com USB 3.1 Tool-free Enclosure | In Stock | £25.00 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £86.89 |
StarTech.com USB 3.1 Gen 2 Adapter Cable | In Stock | £15.01 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £18.94 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £28.25 |
StarTech.com USB 3.1 / eSATA 1-bay Dock | In Stock | £56.18 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £36.88 |
StarTech.com Dual-Bay SATA HDD/SSD Dock | In Stock | £51.98 |
StarTech.com 4 Bay SSD/HDD Docking Station | In Stock | £144.99 |
