Use this SATA hard drive docking station to gain quick access to two of your 2.5" or 3.5" SATA III SSDs/HDDs. This dual-bay SATA HDD/SSD docking station lets you dock and swap drives from your desktop or laptop computer simultaneously, using a single USB port. It supports two 2.5/3.5" SATA hard drives or solid-state drives.
The dual-bay docking station supports USB 3.0, also known as USB 3.1 Gen 1, providing fast data transfer speeds of up to 5Gbps. It also supports UASP, for enhanced performance.
Ideal for IT professionals, such as system administrators and technicians, the hard drive dock enables you to complete device-management tasks more efficiently, such as disk image duplication, data recovery, backing up and archiving hard drives, and transferring content between drives and devices. It also enhances your workflow, by providing quick access to your hard drives, with the ability to easily swap drives in and out as needed.
Designed for easy drive access, the hard drive dock enhances your workflow, by providing quick access to two hard drives, with the ability to easily swap drives in and out as needed. The hard drive dock features a convenient top-loading design with independent drive doors that make it easy to add or remove drives.
The dual-bay SATA HDD/SSD docking station is OS independent, with no drivers or software installation required, for easy setup.
Efficient hot-swap functionality
The docking station features dual hot-swap bays that let users easily swap out drives without system downtime, enhancing workflow efficiency. -
Fast data transfer rates
With USB 3.0 connectivity, this docking station supports data transfer rates of up to 6 Gb/s, making file transfers quick and efficient. -
Broad hard drive compatibility
Compatible with both 2.5-inch and 3.5-inch SATA HDDs and SSDs, this docking station offers versatile support for a range of storage needs. -
Robust construction
Constructed from sturdy plastic and aluminum materials, the docking station ensures durability while maintaining a lightweight profile. -
Reliable operational standards
This product adheres to Plug-and-Play standards as well as FCC, RoHS, and WEEE compliances, ensuring user-friendly and sustainable design.
- StarTech.com Dual-Bay USB 3.0 to SATA Hard Drive Docking Station, USB Hard Drive Dock, External 2.53.5 SATA IIIIII, SSDHDD Docking Station, Hot-Swap Hard Drive Bays - Top-Loading - HDD docking station - SATA 6Gb/s - USB 3.0
- HDD docking station - external
- Bays
- 2
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 2 x hot-swap - 2.5" / 3.5" shared
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Plastic, aluminium
- Power Source
- Included AC adapter
- Power
- AC 100 - 240 V
- 13 cm x 11.4 cm x 6.2 cm
- 730 g
- 2-year warranty
- Designed For
- P/N: SVA12M5NA
- Bays
- 2
- 2.5", 3.5"
- Host Bus
- USB 3.0
- Product Material
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Processor
- ASMedia ASM1153E
- Bays
- 2 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 9 pin USB Type B
- Cables Included
- 1 x USB 3.0 cable - external
- UASP transfer protocol, S.M.A.R.T. support, TRIM support, tested with up to 10TB 7200 RPM hard drives
- Plug and Play, FCC, RoHS, WEEE
- Power Source
- Power adapter
- Voltage Required
- AC 100 - 240 V
- 36 Watt
- Limited warranty - 2 years
- 13 cm
- 11.4 cm
- 6.2 cm
- 730 g
- 5 °C
- 35 °C
- 20 - 80%
- Designed For
- P/N: SVA12M5NA
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.33 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £27.76 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £19.65 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.36 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £34.48 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
StarTech.com Dual-Bay SATA HDD/SSD Dock
