Add a Gigabit Ethernet port to your MacBook, Chromebook or tablet. Gain fast, reliable network access for your MacBook, Chromebook or tablet, even if it doesn't have an Ethernet port. This USB 3.0 to Gigabit network adapter adds a single RJ45 Ethernet port to your computer through your USB 3.0 port. It installs instantly - with no driver required.
Engineered with a quality aluminum housing in a silver finish, the network adapter is the perfect companion for your MacBook, Chromebook or tablet. Compact and portable, this USB network adapter is the ideal laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port.
Ideal for office or home use, the USB 3.0 network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.0 (5 Gbps). You can quickly access very large files over a Gigabit network, saving valuable time every day. The Realtek chipset gives you the assurance of reliable performance.
Get up and running quickly. Simply plug this Ethernet cable adapter into the USB port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software.
Sleek, silver design looks great with MacBook or Chromebook
Engineered with a quality aluminum housing in a silver finish, the network adapter is the perfect companion for your MacBook, Chromebook or tablet. Compact and portable, this USB network adapter is the ideal laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port. -
Powerful Gigabit network connections
Ideal for office or home use, the USB 3.0 network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.0 (5 Gbps). You can quickly access very large files over a Gigabit network, saving valuable time every day. The Realtek chipset gives you the assurance of reliable performance. -
Native driver support makes installation easy
Get up and running quickly. Simply plug this Ethernet cable adapter into the USB port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software. The USB31000SA is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com USB 3.0 to Gigabit Network Adapter - Silver - Sleek Aluminum Design for MacBook, Chromebook or Tablet - Native Driver Support (USB31000SA) - network adapter - USB 3.0 - Gigabit Ethernet x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- 2.5 cm x 6.5 cm x 1.7 cm
- 36 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Capacity
- Jumbo frame size: 9000
- Processor
- Realtek Semiconductor RTL8153
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
- Silver
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Works With Chromebook
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Capacity
- Status Indicators
- Power, link/activity
- Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, surge protection, Jumbo Frames support, Energy Efficient Ethernet, VLAN Tagging (not supported in MacOS)
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45 - female
- UL, FCC, RoHS
- Silver
- OS Required
- 2.5 cm
- 6.5 cm
- 1.7 cm
- 36 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 20 - 90%
