Add Gigabit Ethernet network connectivity to a Laptop or Desktop through a USB 3.0 port. The USB31000SW USB 3.0 to Gigabit Ethernet Adapter adds a single RJ45 Ethernet port to a USB-enabled computer system, with support for Gigabit network connections at full bandwidth when used with a USB 3.0 host connection, unlike USB 2.0 adapters.
This compact USB 3.0 network adapter is backward compatible with older USB 2.0/1.x computer systems (speed limited by USB bus), making it the ideal portable replacement network adapter or laptop accessory. Plus, with support for features such as Jumbo Frames, VLAN tagging and Wake on LAN (WOL), the adapter offers versatile Gigabit network performance for home and business users alike.
Reliable wired connectivity
This network adapter offers a stable connection via an RJ-45 connector, ensuring optimal performance for Internet browsing, gaming, and streaming. -
High-speed performance
With support for data link protocols such as Gigabit Ethernet and Fast Ethernet, this adapter delivers fast data transfer speeds for demanding applications. -
Convenience of USB-powered
This adapter is powered through the USB port, eliminating the need for an external power source, making it portable and user-friendly. -
Versatile compatibility
Designed to work with various operating systems including Mac, this adapter caters to a range of users and devices. -
Enhanced network features
Features such as Wake On LAN, Jumbo Frames support, and auto-uplink provide added functionality for advanced networking needs.
- StarTech.com USB 3.0 to Gigabit Ethernet Network Adapter - 10/100/1000 NIC - USB to RJ45 LAN Adapter for PC Laptop or MacBook (USB31000SW) - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- 2.6 cm 1.55 cm
- Length
- 67 cm
- 27 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Processor
- ASIX AX88179
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab
- White
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Status Indicators
- Link/activity
- WOL, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, VLAN Tagging (not supported in MacOS)
Processor / Memory
- Processor
- ASIX AX88179
- 1 x 1000Base-T - RJ-45 - female
- FCC, RoHS
- White
- Software Included
- Drivers & Utilities
- OS Required
- 2.6 cm
- 1.55 cm
- Length
- 67 cm
- 27 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £20.74 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter | In Stock | £22.54 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White | In Stock | £37.08 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White | In Stock | £20.53 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps | In Stock | £20.00 |
StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port | In Stock | £50.79 |
StarTech.com USB 3.0 Network Adapter-Silver | In Stock | £23.53 |
StarTech.com USB to Ethernet Adapter - 1Gb | In Stock | £19.78 |
