StarTech.com USB 3.0 Network Adapter-Silver
Quicklinx: BLK2WS00 Mfr#: USB31000SA
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Ethernet, Fast Ethernet
Form Factor: External
Compatibility: Unix, Mac, PC
Type: Network adapter
10 In Stock
£24.84 ex VAT
£29.80 inc VAT
Add a Gigabit Ethernet port to your MacBook, Chromebook or tablet. Gain fast, reliable network access for your MacBook, Chromebook or tablet, even if it doesn't have an Ethernet port. This USB 3.0 to Gigabit network adapter adds a single RJ45 Ethernet port to your computer through your USB 3.0 port. It installs instantly - with no driver required.
Engineered with a quality aluminum housing in a silver finish, the network adapter is the perfect companion for your MacBook, Chromebook or tablet. Compact and portable, this USB network adapter is the ideal laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port.
Ideal for office or home use, the USB 3.0 network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.0 (5 Gbps). You can quickly access very large files over a Gigabit network, saving valuable time every day. The Realtek chipset gives you the assurance of reliable performance.
Get up and running quickly. Simply plug this Ethernet cable adapter into the USB port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software.
  • Sleek, silver design looks great with MacBook or Chromebook
  • Powerful Gigabit network connections
  • Native driver support makes installation easy
    Get up and running quickly. Simply plug this Ethernet cable adapter into the USB port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software. The USB31000SA is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB 3.0 to Gigabit Network Adapter - Silver - Sleek Aluminum Design for MacBook, Chromebook or Tablet - Native Driver Support (USB31000SA) - network adapter - USB 3.0 - Gigabit Ethernet x 1
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
2.5 cm x 6.5 cm x 1.7 cm
36 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Jumbo frame size: 9000
Realtek Semiconductor RTL8153
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
Silver
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Works With Chromebook
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
Status Indicators
Power, link/activity
Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, surge protection, Jumbo Frames support, Energy Efficient Ethernet, VLAN Tagging (not supported in MacOS)
Processor / Memory
1 x 1000Base-T - RJ-45 - female
UL, FCC, RoHS
Silver
2.5 cm
6.5 cm
1.7 cm
36 g
70 °C
20 - 90%
BLK2 StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £38.96
BLK2 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White In Stock £21.66
BLK2 StarTech.com USB 3.0 Network Adapter-Silver In Stock £24.84
BLK2 StarTech.com 3Pt Portable USB 3.0 Hub + GbE In Stock £35.58
BLK2 StarTech.com USB to Ethernet Adapter - 1Gb In Stock £19.76
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: Unix
Compatibility: Mac
Compatibility: PC
