StarTech.com USB 3.0  Dual Hard Drive Docking Station with UASP for 2.5/3.5in SSD / HDD – SATA 6Gbps
Quicklinx: 9KZHWS00 Mfr#: SDOCK2U33
Type: Storage controller
HD Size: 2.5, 3.5
Power Supply: [N/A]
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£61.50 ex VAT
£73.80 inc VAT
Dock two 2.5" or 3.5" SATA III SSDs/HDDs over USB 3.0 with UASP. The SDOCK2U33 Dual 2.5/3.5" SATA hard drive docking station lets you dock and swap drives from your desktop or laptop computer simultaneously, using a single USB port.
Enhanced with UASP (USB Attached SCSI Protocol), this hard drive docking station lets you get the most out of the fastest drive technologies such as SATA III (6 Gbps), solid state drives (SSD) and hybrid, drives with performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
The hard drive dock features independent power buttons for each individual drive, ensuring you can operate each hard drive separately. This gives you the freedom to hot-swap one drive while transferring data to another, saving you time.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in. IDE hard drive into a SATA hard drive dock.
To ensure compatibility with your computer system, the SDOCK2U33 supports all of the leading operating systems, including: Microsoft Windows (8/7/Vista/XP/Server 2008/Server 2003), Apple OSX (10.9/10.8/10.7/10.6), Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
  • Improved Performance with UASP
    UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance. At the same peak in testing UASP also shows an 80% reduction in required processor resources. Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com Dual-Bay USB 3.0 to SATA Hard Drive Docking Station, USB Hard Drive Dock, External 2.53.5 SATA IIIIII, SSDHDD Docking Station, Hot-Swap Hard Drive Bay - Top-Loading - storage controller - SATA 6Gb/s - USB 3.0
Storage controller - external
Bus Type
USB 3.0
Expansion Bays
2 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
2
AC 120/230 V
Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.6 - 10.9
14.8 cm x 13.2 cm x 7 cm
532 g
P/N: SVA12M5NA
2.5", 3.5"
Host Bus
USB 3.0
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
2
ASM1053E / VIA812
Bays
2 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B
1 x USB 3.0 cable - external
Tested with up to 4TB 7200 RPM 3.5" hard drives, tested with up to 2TB 5400 RPM 2.5" hard drives
FCC, RoHS
Power adapter
AC 120/230 V
14.8 cm
13.2 cm
7 cm
532 g
5 °C
35 °C
20 - 80%
P/N: SVA12M5NA
9KZH StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
9KZH StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
9KZH StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
9KZH StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £14.68
9KZH StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
9KZH StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD In Stock £63.79
9KZH StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.68
9KZH StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £54.05
9KZH StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
9KZH StarTech.com Dual-Bay SATA HDD/SSD Dock In Stock £51.66
HD Size: 2.5
HD Size: 3.5
Power Supply: [N/A]
