StarTech.com DC Power Adapter - 12V, 5A
Quicklinx: CWSDWS00 Mfr#: SVA12M5NA
11 In Stock
£44.00 ex VAT
£52.80 inc VAT
Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device that has an M type barrel jack and requires 12volts and up to 5amps of power. The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics. When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
  • Replace your failed or lost power adapter
  • Keep a spare power adapter on hand
StarTech.com Replacement 12V DC Power Adapter - 12 Volts 5 Amps - Power adapter - AC 100-240 V - SVA12M5NA - power adapter
Power adapter - external
Australia, Japan, North America, United Kingdom, Europe
Input Voltage
AC 100-240 V
Output Voltage
12 V
Power plug adapter (EU), power plug adapter (UK), power plug adapter (AU), power plug adapter (NA)
StarTech.com 4-Port Industrial USB 3.0 5Gbps Hub, Rugged USB Hub w/15kV Air/8kV Contact ESD and Surge Protection, DIN/Wall/Desk Mountable USB-A Hub, USB Expansion Hub with Locking Ports - Metal Construction (5G4AINDNP-USB-A-HUB)
Input Voltage
AC 100-240 V
Output Voltage
12 V
Max Electric Current
5 A
Power cable
UL, FCC, RoHS, WEEE, RCM
CWSD StarTech.com VGA to Cat 5 Monitor Extender Kit (250ft/80m) - VGA Cat5 Extender In Stock £123.01
CWSD StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length In Stock £333.85
CWSD StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £255.35
CWSD StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £115.45
CWSD StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £43.31
CWSD StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub In Stock £161.02
CWSD StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £252.15
CWSD StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £134.52
CWSD StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £198.98
CWSD StarTech.com DisplayPort USB KVM Switch In Stock £235.68
CWSD StarTech.com PCI Express to 4 Slot PCI Expansion System In Stock £376.57
CWSD StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio In Stock £93.76
CWSD StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £103.00
CWSD StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £473.62
CWSD StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
CWSD StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £18.33
CWSD StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £128.51
CWSD StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £287.42
CWSD StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £323.73
CWSD StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
CWSD StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter ST 2 km In Stock £73.59
CWSD StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m In Stock £159.26
CWSD StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps In Stock £161.25
CWSD StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter SC 2 km In Stock £74.79
CWSD StarTech.com USB Dual VGA over Cat5 KVM Console Extender - 650 ft / 200m In Stock £351.76
CWSD StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £192.41
CWSD StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed In Stock £312.49
CWSD StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £26.11
CWSD StarTech.com 2 Port HDMI Switch w/ Automatic and Priority Switching - 1080p In Stock £59.93
CWSD StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p In Stock £87.36
CWSD StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD In Stock £67.18
CWSD StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
CWSD StarTech.com USB 3.0 Dual Hard Drive Docking Station with UASP for 2.5/3.5in SSD / HDD – SATA 6Gbps In Stock £61.51
CWSD StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps In Stock £73.55
CWSD StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library In Stock £275.46
CWSD StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall In Stock £637.10
CWSD StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £67.46
CWSD StarTech.com USB HDD dock for SATA & IDE In Stock £65.66
CWSD StarTech.com USB 3.0 Standalone Eraser Dock In Stock £216.09
CWSD StarTech.com GbE Fiber Media Converter 10km In Stock £188.09
CWSD StarTech.com GbE Fiber Media Converter 20km In Stock £171.00
CWSD StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £258.12
CWSD StarTech.com USB and SATA Cloner / Eraser In Stock £481.95
CWSD StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn In Stock £244.60
CWSD StarTech.com USB C to SATA Adapter Cable In Stock £36.42
CWSD StarTech.com Dual-Bay SATA HDD/SSD Dock In Stock £54.05
CWSD StarTech.com 4 Port USB 3.0 Hub A to C & A In Stock £44.11
CWSD StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £41.80
